Reverse in a 2008 base model
Discussion in 'Gen 2 Prius Main Forum' started by combsad7, Aug 6, 2010.
  1. combsad7
    combsad7 Junior Member
    51
    Western Kentucky USA
    When I visit my family I have back up a 1 mile plus drive way, no place to turn around. I notice my display drops to one pink bar. I guess my Prius does not charge in reverse.
  2. kimgh
    kimgh Member
    297
    San Jose, CA
    Nope. No charging in reverse. Just the way it's designed.
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    combsad7,
    I'm really impressed that the Gen II will run in reverse for a mile.
    I'd bet I've never backed-up for even 100 ft.
    IIRC, the car will only go ~1.5 miles forward in EV mode with a full
    battery.
    Two questions:
    Do you start your run in reverse with a "full" HV battery?
    Do you back-up because of difficulties caused by the Traction Control
    on gravelly, leaf covered, or otherwise slippery surfaces, or is it just
    a narrow roadway with no turn-around even at the end? :confused:
    I've never experienced anything like this and I like to try to know more
    about how the Gen II operates than just what I typically see on a daily
    basis -- just in case. You never know what tomorrow may bring.
    51,141
    what happens when the battery gets too low, ice?
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I -thought- Prius DOES charge in "R", just not in "N". It can also generate power with the ICE and MG1 and feed it to MG2 while in "R". It does not use the ICE to power the wheels in "R" as there is NO reverse gear. "R" is "backwards turning" of MG2 only (the inverter does this via computer control).
    Note that if you just started the car, it will not "want" to generate or use a lot of ICE power due to the cat warm-up low emission cycle. If you wait a minute or so you get past this limit.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    ICE can recharge the battery in reverse. HSD just tries to avoid it because it is inefficient.
    HSD in reverse is in pure Series hybrid mode. It is powered only by electric motor. ICE does not turn the wheel in reverse direction.
