Reverse Light short, shift gear stuck in park
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by HugoUS, Nov 26, 2018.
  1. HugoUS
    HugoUS New Member
    2014 Prius c
    Hi guys, I am new here and need help. I tried to wire back up camera to reverse light and accidentally short it. Now my car stuck in park and the only way to shift it is press the shift lock. Even when I shift it to R, no reverse light. I check all the fuse related to brake system and they are ok. What next to check?
    49,506
    welcome!
    have you disconnected the wire and put everything back to oem spec?
  3. HugoUS
    HugoUS New Member
    2014 Prius c
    Yes, I disconnected the camera but still cannot shift. No error or CEL.
    49,506
    how is the 12v health?
  5. HugoUS
    HugoUS New Member
    2014 Prius c
    Never mind, I just found the blown fuse of backup light. It's the same one for shift lock. Everything is ok now, thanks guys.
    ztanos and bisco like this.
  6. bisco
    49,506
    well done!
