Reverse polarity issue 2009 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by arlofleenor, Oct 6, 2025 at 7:13 PM.
  1. arlofleenor
    arlofleenor New Member
    Yesterday
    My 2009 Prius died after having not been driven for a week or so. This was an almost brand new battery. All attempts to charge it have resulted in a "reverse polarity" indication even though the polarity is correct. Must be a shorted battery, but seems weird for a new battery... any advice?
  2. Brian1954
    Brian1954 Senior Member
    2,021
    790
    South Central PA, USA
    Return the 12v battery for warranty replacement.
  3. Tombukt2
    Tombukt2 Senior Member
    12,716
    2,272
    Durham NC
    If you plug up the charger to another battery and correctly connect the leads red to plus black to minus and so on does the charger fail on that battery if yes maybe the charger.
  4. Hayslayer
    Hayslayer Member
    337
    182
    Yes, please post photos of the battery as it sits installed in the car and the charger.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,025
    1,950
    NJ-USA
    Use a digital multimeter to measure the actual voltage at the battery terminals.
    Have you used this charger before? Does it work correctly on another battery?
