Reverse Signal Wire for Prius C ONE / TWO
Discussion in 'Prius c Audio and Electronics' started by wmo168, Apr 12, 2013.
  1. wmo168
    wmo168 Member
    239
    49
    South Florida
    Does anyone know where exactly we can tap the wire under the dash for Reverse Signal for Prius C One and Two? I know 3/4 has the wire coming out to the Radio.
    I believe the wire is purple but want to know where the harness is under the dash. Don't want to run the wire from the bulb from the back.
    This is for the Backup Camera.
    Thanks!
  2. 2015Prius2
    2015Prius2 Member
    150
    67
    Check for plug labelled "3d" under the dash, it will be a 36 pin white plug. Look for a brown wire in pin 28
  3. wmo168
    wmo168 Member
    239
    49
    South Florida
    Thank you! I will look for that and use it as a signal for the back up camera.
  4. 2015Prius2
    2015Prius2 Member
    150
    67
    No problem, let me know if that worked for you
  5. wmo168
    wmo168 Member
    239
    49
    South Florida
  6. LordsII
    LordsII New Member
    16
    Reverse wire under dash? Did you mean the harness behind the head unit that connects to this HU?
  7. KYBlue
    KYBlue Active Member
    227
    112
    Ever find this? I need the same info.
    Thanks,
    C
  8. wmo168
    wmo168 Member
    239
    49
    South Florida
    As it turns out you don't need the reverse signal at all for the backup camera. The kit I work will show the camera automatically when I put the car in Reverse "R"
  9. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    What kit do you have gor the backup camera?
  10. wmo168
    wmo168 Member
    239
    49
    South Florida
    I got Echomaster $125 from ebay... It plug and play and don't need to cut anything.
  11. KYBlue
    227
    112
    What about for C1/C2 guys - plug and play is a no go, I'll have to find the wire....
  12. wmo168
    wmo168 Member
    239
    49
    South Florida
    Which radio are you installing in your C2? if you have the Stock C3C4 Nav or Toyota Corolla one then it should be plug and play.
  13. KYBlue
    227
    112
    See my thread in this forum, I put in an aftermaket JVC...
  14. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I would like to find the wire too. Better to find it in the front than run a wire from the actual reverse light
  15. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    I just installed a generic camera ($13, ebay) and a Crimestopper SV-9154 ($121, Amazon) in the C1 this past weekend.
    I bought a small spool of stranded/shielded 22/2 insulated security system wire and ran that from the front of the headliner (popped out the dome light) to the back of the headliner using 3 pieces of fiberglass wire puller.
    Since it is 22/2 and shielded, I used the black wire for the video signal (soldered RCA jacks on both ends when done pulling wire). The red was tapped to the reverse light bulb wire to power up both the ACC 12V + and the Reverse signal (green wire) on the mirror (don't want auto dim function). There's plenty of sheet metal to drill into for ground (under the dome light there's metal brace holding the light assembly and on the rear wiper bracket in the hatch . The camera got a 2nd red wire connected to the reverse light. Surprisingly, everything looks stock. The camera screwed onto the stock location neatly. I notched that plastic trim piece in the rear (where the camera attaches to) for the wire and lead the wire through the foam seal under the license plate light clear lens (also slightly notched with a round file). No drilling of the hatch was needed.
    The hard part was using the fiberglass rods to pull the wire through the middle of the headliner. There are large pieces of foam glued underneath, so there's only one path that works. I kept at it until the yellow rod made its way to the dome light hole (with dome light removed).
  16. johnhlong
    johnhlong Junior Member
    89
    29
    East Carbon, Utah, USA
  17. johnhlong
    89
    29
    1> Which camera did you purchase, eBay auction # ???
    2> Where is the stock camera location on a 2013 Prius C2 ? (Same as C1 ???) Pictures ???
    John
  18. tk1971
    253
    133
    SG Valley, CA
  19. johnhlong
    89
    29
    I love it!
    John
  20. johnhlong
    89
    29
