Reversed Jump Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gwapo82, May 7, 2020.
  1. Gwapo82
    Gwapo82 New Member
    Oklahoma
    Four Touring
    Hello all and thank you for reading all this mess!
    I had my ABS actuator go out so I ended up replacing it myself after running the gauntlet of cursewords. I took my time on this and didn't get to it for a week+ and the 12V battery died on me. I jumped it, tested the brakes, and everything was fine, the battery just didn't charge back up.
    So I go out tonight to see if I can leave it running and I dumbfoundedly reverse polarity on the cables but quickly take them off seeing what I did. I put them back on quickly and voltmeter the battery while it's on jump and it reads 13.5 to 13.8.
    I put the key in to start, and the start button lights up, along with the park button light. The only light in the dash that comes on is the check engine light. I went to the front of the vehicle and checked the 100a fuse and the metal parts look to be connected and not damaged. It sounds like the ABS motor or the inverter are clicking. Is there anything I needed to check?
    Thanks for all the advice and have a better night than me!
    49,371
    check the 12v health, then check the fuse continuity
  3. Gwapo82
    Gwapo82 New Member
    Oklahoma
    Four Touring
    Got a new battery in, there were two fuses that were bad, BAT FAN and DOME, both replaced. Now the cars check engine light is off and when I try to power it, it makes a whirrr sound and nothing lights up on the dash.
  4. Gwapo82
    Gwapo82 New Member
    Oklahoma
    Four Touring
    I think I may have found the problem.
    wookie_73 and bisco like this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    if it was me I would just jump it out. Bust out the plastic cover and solder across it. See if the car starts. It may have a blown inverter.
    It took a real good reverse polarity. Thats a big fuse. I say just jump it because the car could be severely damaged and best to know now without spending anymore time and money on it. if it starts great then replace that fuse block correctly.
    Your probably jumping directly to the 12 volt battery in the hatch..
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,890
    Columbia, SC
    Your photo is very standard for a reversed jump start. A blown fusible link and a couple blown fuses. Replace them and the car will very likely fire right up.
    Yes, you can remove the plastic cover and jump across the open link. I've done it before by wedging a couple pennies on each side. (not my car) Actually, three pennies on driver side and 5 pennies on passenger side. That will get you going, but please don't us it as a permanent repair, lol. One big bump in the road and pennies may go flying.
    #6 TMR-JWAP, May 9, 2020
  7. Gwapo82
    Gwapo82 New Member
    Oklahoma
    Four Touring
    So I replaced the dead battery with a new one and the fusible link box and the car powers on but all the gears flash along with the fuel gauge. Any ideas on this, the new battery reads 11.88, do I need to get it up some with a proper jump?
  8. edthefox5
    10,096
    4,804
    Clearwater, Florida
    First how are you jumping the battery?
    You need to read the OBD codes its throwing. I guarantee its throwing some. It will tell you what system its unhappy about. Did you pull every single fuse in the car the engine box and the kick panel box in the cabin and test with an ohmmeter?
    When you say it starts does it drive? or its just throwing these flashing lights and you are calling that starting.
    Starting means the word READY is shown on the dash and the engine starts.
  9. Gwapo82
    Gwapo82 New Member
    Oklahoma
    Four Touring
    I'm going to get techstream and see what codes it has for me as I don't have an obd scanner. I've pulled every fuse in the car and replaced the ones that were bad. I've tried jumping at the "under the hood" fuse box jumper and no luck. Reading the voltmeter while jumping reads 12.94.
    It doesn't READY, it is just flashing all the gears and the fuel gauge with ABS VSC (!) MAINT REQ etc, I'll show in a picture attached to this.
    I'm just lost at what to do. Should I go down and get an obd or just break down and rent techstream? Thanks for the help!
    #9 Gwapo82, May 13, 2020
  10. TMR-JWAP
    6,193
    5,890
    Columbia, SC
    I don't know if this info will help or not.
    A loss of 12v power will cause:
    1. fuel gauge to flash one dot until it recalibrates (could be 2 minutes or hours)
    2. loss of radio presets
    3. loss of driver window auto up/down feature
    Low 12v power will cause the squares around the gear indicators to flash (I've seen this happen when battery voltage was around 8-9 volts.
    I'm pretty sure the last time I helped someone who reversed jumper leads, there were 3 blown fuses in the underhood fuse box, in addition to the blown fusible link. Checking them all again is inexpensive.
    The power source ecu may be involved in this issue. May want to search that subject and see if any similar symptoms are mentioned..
  11. edthefox5
    10,096
    4,804
    Clearwater, Florida
    Nowhere to rent tech stream.
    Your going to need a hybrid capable obd code puller no matter what.
    There's VXdiag or mini vci or phone apps Dr Prius or Torque. Use the search forum tab up top and search all those for what fits you best. I have TS and VX. VXDiag on amazon is plug and play mini vci not so much. Both use TS both require a laptop.Phone apps are not TS but will work to pull the codes.
    Whats the voltage read at the front jump point to ground with nothing attached to the front jump point? Then turn on the headlights in high beam and while there on read the voltage again. Post those 2 back here. Its probably ok but if I was called there thats the first thing I would do.
    Ground is the bolt head right above the black box.
    This is why i always recommend do anything you can to keep a healthy 12 volt battery in this car because jump stating it is extremely dangerous to your wallet and sanity. We have seen this scenario hundreds of times on this site.
  12. Gwapo82
    Gwapo82 New Member
    Oklahoma
    Four Touring
    Ok I totally am a dummy. I guess when I was bent over backwards stretching my poor back out, I put the IGN fuse in the wrong spot. I put it back in the correct place and now I have....
    ! CAUTION There is a problem with the transmission "P" lock mechanism. Park your car on a float surface, and fully apply the parking brake.
    Now on to this problem and I believe I'll be done!
    Fingers xx
    #12 Gwapo82, May 15, 2020
  13. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    Check your 12 V battery and charge it up* if it is 12.1 V or less. A new AGM battery should be holding 13.1 - 13.3 V when fully charged.
    * Or load test it and replace it if necessary (under warranty) – maybe your new battery is defective, especially as you mentioned it was only 11.88 V at one time.
  14. Sam Stone
    Sam Stone Member
    63
    George,
    Thank you so much for jumping in. I was reading about the issue online and discovered the stoopid thing has an immobilizer complete with its very own fuse. I'll be checking your idea and this fuse as soon as I'm alone tomorrow. It's not technically "working" on a car if that's a I'm doing is it?
    Thank you again. I'll let you know.
  15. offib
    offib Member
    162
    94
    Dublin
    Four Touring
    Hey folks. I've seem to have run into the sane problem. My da jump started the car from the front terminal, the donor car had its polarity reversed, and disaster. The lights were forced on with the switch gear off.
    None of the lights work, except for an engine light and the audible brake pump when I try to start it. I've no idea what fuse to test with a phase tester. The 12v is fine now. Perhaps the ignition fuse I'm trying to find inside the cabin.
  16. ChapmanF
    15,435
    These things happen. They typically result in some blown fuses. Not necessarily any other serious damage, but one kind of has to find the blown fuses first, and then find out how everything else held up.
    There isn't a fixed recipe for exactly what will have blown in each car this happens to. There are some more and less usual suspects. You can follow a thread about DMAndy's 2006 that makes a good illustration of how the sorting-out process can go. As you can see, it starts with the wiring diagram, which DMAndy looked up and made frequent reference to.
    A caution against viewing the sequence of posts and steps in DMAndy's thread as a fixed script. If you read closely, you'll see that each later step in a later post was a response to whatever DMAndy found and reported in an earlier post. The pattern is look at the diagram, identify something you can check, check that, get your result, look back at the diagram to see what your result tells you, then pick a next thing to check. The exact sequence of steps you'll improvise depending on what you find from one step to the next.
    offib likes this.
  17. offib
    offib Member
    162
    94
    Dublin
    Four Touring
    {UPDATE} Hey so several weeks la-ter; after I had the 100 amp fuse blown. and two small other ones, the main power converter had been affected too somehow. With a new 100A it resurrected the car with ready mode on, coolant pump working fine etc, the Screen had two or three red square engine warning lights all over, and after 30 seconds just one red 12v battery square.
    I had the car's power converter replaced with one from a parts car for 50 dollaroos, and then it keeps on running.
  18. dolj
    dolj Senior Member
    7,628
    3,849
    While this "worst-case scenario" sometimes is the case, more often than not the 100 A fuse does its job and saves the day.
    But it is worth noting that the inverter can get damaged and need replacing.
    offib likes this.
  19. wookie_73
    wookie_73 Junior Member
    UK
    Thanks for this. Helped out massively.
    Jump leads were hooked up wrong way round to prius this morning. Spent all morning replacing battery then checking all fuses. Found a couple gone but car would still not come to life.
    Resorted to trawling through forums for some kind of idea.
    Found your photo of the fuseable link in the busbar. Checked under the now quite yellow plastic cover and hey presto problem solved.
