Reversed polarity
Discussion in 'Prius c Technical Discussion' started by Manveer Gill, Jan 25, 2019.
Thread Status:
Not open for further replies.
  1. Manveer Gill
    Manveer Gill New Member
    Winnipeg cad
    Hey guys i have a 2013 Prius c which I bought from a auction to rebuild. The 12v battery was dead when I got it so I took it out and got it charged up when replacing the battery, I accidentally hooked up the wrong terminals and as doing that it caused a spark and the horn went off I immediately took the wires off and flipped the battery. I went to go start it the dash light up and gave me the message to check the hybrid system while giving the engine gas it would run but turn off after few seconds. I started checking the fuses and the 100a fuse is blown and so is the dome fuse and the abs fuse. Does anyone know how to replace the 100a fuse I can't seem to find how to get to the bottom wires to unbolt it and I hope that inverter is okay otherwise that's gonna be a expensive fix
    Vit@liy likes this.
    49,693
    welcome!
    not sure, have you looked in the service manual?
  3. Manveer Gill
    Winnipeg cad
    All the service manual says is to take it to the closest dealership
    49,693
    that's the owners manual
    techinfo.toyota.com
  5. Manveer Gill
    Winnipeg cad
    Thanks bisco but i dont see anything on there for the 100a fuse and how to replace it
  6. bisco
    49,693
    search google and click on PriusChat hits. it has been described here before
Thread Status:
