Reving after releasing gas.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by jamz111, Sep 15, 2014.
  1. jamz111
    jamz111 New Member
    I noticed that when I'm stepping on the gas pedal, revving up, when I release the gas pedal I can hear the engine revving up some more instead of slowing down.
    When I release the pedal even if the revolution light on the dashboard shows that it is slowly dropping, the engine is still making the noise as if I am stepping on the gas harder for about a second.
    Example: I am at a stop, when I start going from 0 to 30 mph, if I release the gas right away thats when I notice this issue.
    This doesnt happen when I'm cruising on the same speed and suddenly release the gas.
    I wonder if this is an indication the my tranny is having a problem.
    I have a 2013 prius C 2
    Any help will be appreciated.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I've noticed this as well, but only when the car is still cold and not warmed up yet.
  3. thetakara
    thetakara Junior Member
    36
    I'm having this issue also. I just noticed it today. I have a 2013 C3 with ~19700 miles on it. I'll be taking it in tomorrow if it continues. I'll post updates if needed.
    #3 thetakara, Sep 26, 2014
    52,380
    please do, thanks!
  5. Sandal
    Sandal New Member
    Colombo
    I have been having the same issue as well..and becuz the engine revs up abnormally..it doesnt go to EV mode even at lower speeds..please keep us posted. tks
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Thetakara, Sandal. Can either of you confirm if it does this after the car is warmed up? Or does it only do it for the first couple of miles and then act normally.
  7. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    was going through the grapevine, when I got caught in stop and go traffic (for a good hour)...engine would do so said behavior...however, the battery was also getting low (2bars) from the stop and go, so I'd say it's normal behavior for the engine to want to rev some to charge the battery some
    minkus likes this.
  8. thetakara
    36
    I haven't taken the car to the dealership yet. Yes, this was happening after the car was warmed up. I had been driving around for like 45 minutes or so.
    I checked the car and realized that there was a garbage bag blocking one of my traction battery vents. Might want to check on that first. Since removing the bag, this issue has gone away. When I'm out of school in a few hours, I'll stop by the dealership and ask the service department if they can think of anything offhand that would cause the symptoms.
    Mike4kz, minkus and ztanos like this.
  9. jamz111
    jamz111 New Member
    Mine does this when its warmed up
    ztanos likes this.
  10. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    funny story: plenty road construction traffic. i was waiting because the cop waved Stop. of course i am first in line. my Prius c One decides to charge the battery a bit and start revving the engine super high. so the cop turns and looks at me like I'm doing it. i just kinda shook my head no and the cop then stared down the car thru the hood. i think the cop growled at my car. i am sure he was about to shoot it right thru the engine block. then the Prius suddenly shuts off. so the cop then smiles at the car, smiles at me & waves me on to go. whew,,,
  11. jamz111
    jamz111 New Member
    I took my car to the toyota dealership yesterday. They said there's nothing wrong that they can find but could not explain to me why the car is doing what its doing. smh
  12. bisco
    52,380
    idiots.
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Where are you located? Maybe it never gets warm enough to quit the behavior? How far do you consider warmed up? This morning on my way to work it behaved like this the entire commute. But then again, my commute is less than 10 miles.
    Can you take a video of the car doing it so that we can see if there is anything we can catch out of the normal?
  14. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    Not sure if any of this applies to your situation, but:
    This has happened to me once. I was leaving a concert and waiting in line to get out. I was parked on grass and there was a lot of low speed driving when entering to park, so the battery was almost drained. I started the car and drove a bit to get to the line of cars, and when the line inched up, I accelerated a bit, which made the engine rev less. When I took my foot off the gas, the engine revved up. After doing that a few times, the engine shut off. It may have happened a second time, while I was stuck in traffic somewhere else.
    I assumed that was normal behavior for when the engine is warmed up but the battery state of charge falls below an acceptable level. It's also possible that the battery vent was blocked, because I don't remember if I checked that or not (edit: it happened again, same scenario and same place. vent not blocked).
    #14 minkus, Oct 7, 2014
  15. Twizzle
    Twizzle New Member
    Canberra, Australia
    My car started playing up about a month ago, occasional revving up when the accelerator was released, not going into EV mode (switch) then sometimes started refusing to turn the engine off when coasting when fully warmed up, dropping into EV at random speeds when coasting down, and the fuel economy started to suffer. The car has just over 38,000km on it (in 11 months).
    It went in to Toyota today to investigate the problem, they didn't have a clue, even when I went back later and took a tech for a drive and showed off the odd behaviour when fully warmed up.
    When I got home, I found there is a mesh screen on the front of the traction battery fan and it was blocked by fluff from the carpets. I removed the plastic cover, vacuumed the screen and the car now appears to be working properly again. Looking at the service items on the checklist, checking/cleaning the fan screen isn't a maintenance item - but it really should be! So - shine a torch in the air inlet and see how much fluff is in there.
    kadeR, minkus and robertmaria like this.
  16. Twizzle
    Twizzle New Member
    Canberra, Australia
    Just to add... cleaning the screen has made a HUGE difference in urban fuel economy, in the region of 10%. While economy had sat between 4.1 - 4.4lt/100km (mainly depending on temperature), I'm having no trouble achieving 3.7lt/100km now. That damned battery must have been overheating for most of the time we have had the car.
  17. grill vogel
    grill vogel Junior Member
    Toronto
    2015 Prius c
    Hey guys I am having trouble locating this traction battery fan you guys speak of. I don't know much about the anatomy of my Prius c. I have this problem and want to clean this fan or vent but have no clue where it is and how to remove anything. Any help is appreciated. I'm a noob.
  18. bisco
    52,380
    welcome! the vent intake grille should be located somewhere on the face of the back seats near the seatbelt, or below the cushion. you can find it in your owners manual. the fan is a bit more complicated, and requires removal of some of the hatch area panels. if someone doesn't jump in here who knows where it is, try starting a new thread. all the best!(y)
  19. grill vogel
    Toronto
    2015 Prius c
    Thanks bisco. I'll take a look at the manual. should have done that first. Lol cheers
  20. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    Under the left-rear seat you'll see the grille. The round button-looking things are push snaps. Remove those, and the plastic shroud comes out, and you have access to the fan. No need to remove the fan, just clean the inlet screen with vacuum.
