Rewiring the shifter
Discussion in 'Gen 2 Prius Technical Discussion' started by wba, May 23, 2007.
  1. wba
    wba New Member
    Has anyone figured out how to rewire the shifter to reverse the sequence so that park is out and drive is in?
    (2002 Prius)
    Thanks,
    Sore knee
  2. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Why would you want to do that?
    Besides, park is on a separate button, not part of the shifter, at least on mine.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< IMO, the well-thought-out design of the Prius shifter (and many other elements) would be very difficult to improve.
    My 2¢
  4. just_marci
    just_marci New Member
    49
    I have nothing to add to this conversation, but...
    WOO! Another Pittsburgher!
  5. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(subarutoo @ May 23 2007, 12:35 PM) [snapback]448416[/snapback]</div>
    The OP drives a previous generation Prius.
  6. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    The older generation Prius is different and by the OP's signature I'm guessing his knee hits the shifter when it's in drive.
  7. wba
    wba New Member
    <div class='quotetop'>QUOTE(San_Carlos_Jeff @ May 23 2007, 06:53 PM) [snapback]448548[/snapback]</div>
    That's it exactly, I'm 6'4" and it's my only complaint. Surely it's just a sequence of pins in a connector to map the shifter position to the transmission signals. Wouldn't it be great to be able to see the dashboard while you're driving?
  8. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    <div class='quotetop'>QUOTE(Pittsburgh Bill @ Jun 1 2007, 01:59 PM) [snapback]453354[/snapback]</div>
    not exactly. it's a pretty substantial mechanical device. there is a type of switch inside there, but the first gen prius has a steering column lock. so even if you rewire the switch successfully, you wouldn't be able to turn the steering wheel when you shift to drive.
  9. wba
    wba New Member
    <div class='quotetop'>QUOTE(galaxee @ Jun 1 2007, 09:53 PM) [snapback]453706[/snapback]</div>
    You're right, I opened it up and there are several mechanical interlocks, reversing does not seem feasible.
    thanks!
