right front fan no worky : (
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Uberdriver2710, Nov 26, 2022.
  1. Uberdriver2710
    Uberdriver2710 Junior Member
    30
    usa
    I'm long time lurker. I think I've only posted just once.
    Anyway... my 2015 gen 3 Prius is close to 160k miles.
    I do my all own maintenance, except for tires. I have been working on cars since 1991.
    Aside from typical oil changes, MAF sensor cleaning, etc. I've done the thermostat, water pump, pcv valve, cleaned the air intake and EGR pipe (which were not that dirty at all).
    Now... my right front fan is out. Which I verified, by putting the car into maintenance mode.
    I pulled the air box out to get a look at the fan assembly. I'm stumped on how to get this thing out. I just wanted to check the fan, before checking the relay.
    Any help would be great!
  2. Elektroingenieur
    2,515
    3,277
    Three Touring
    The Repair Manual (more info) procedure says to remove the radiator assembly first, after which you can remove the fan, no. 2 fan, no. 2 cooling fan motor, and cooling fan motor.
    Perhaps in part because this would be so much work, the manual also has a 23-step diagnostic procedure for the cooling fan circuit and an on-vehicle inspection procedure for the cooling fan motors, so before replacing one, you could be sure it’s not a fuse, relay, or wiring problem.
    douglasjre and Uberdriver2710 like this.
  3. Uberdriver2710
    30
    usa
    Thanks, the fan feels ok. I'll move on to the relay.
    Elektroingenieur likes this.
  4. hoffeck
    hoffeck Member
    Germany
    What happens to the fan when you turn on the air conditioner?
    Uberdriver2710 likes this.
  5. douglasjre
    douglasjre Senior Member
    2,095
    701
    Null, NL
    Techstream offers bidirectional support. Command fans on. Test for 12v. Find where it no workie w 12v meter or 12v test probe
  6. Uberdriver2710
    30
    usa
    if it's cold outside, nothing
    if it's warm, the one good fan cycles on and off
  7. Uberdriver2710
    30
    usa
    hmmm...I was thinking of getting the Techstream. I may look into that soon.
  8. douglasjre
    2,095
    701
    Null, NL
    You don't have a choice. This is how ASE cert mechanics do diagnostics
  9. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    How did you get junior member status with only just one post?
  10. Mendel Leisk
    40,575
    Avatar says 11 posts, and member since March of 2019.
  11. Uberdriver2710
    30
    usa
    Maybe more like 1%. I'm on a few other forums, so I lose track. They're all different. : )
    #11 Uberdriver2710, Nov 27, 2022
  12. Uberdriver2710
    30
    usa
    nah, My wallet makes the choice. : )
    #12 Uberdriver2710, Nov 27, 2022
  13. Uberdriver2710
    30
    usa
  14. ChapmanF
    17,326
    If I had one I sure would. I've said all kinds of intemperate things around those relays.
  15. Uberdriver2710
    30
    usa
    I just ordered a pair. It's around $10 with free shipping, thanks to walmart. : )
    I really don't want to break any relays.
  16. Mendel Leisk
    40,575
  17. Uberdriver2710
    30
    usa
  18. Mendel Leisk
    40,575
    Breaker wrench is good too, basically a ratchet wrench with extra long handle. Preferably with swivel head. That's my goto as often as not; makes things a lot easier.
