Right Hand Upper Engine mount torque and temp sensors
Discussion in 'Gen 4 Prius Technical Discussion' started by Soobz, Dec 26, 2024.
  1. Soobz
    Soobz Junior Member
    LA, CA
    I
    Hello,
    was wondering if anyone has the torque amounts for the 3 nuts on the Right-hand upper engine mount. there's two nuts on top and one accessible from under. It's the same engine mount we un-mount when lowering the engine for water pump replacement.
    Another question...Does the gen 4 (2017) have three temp sensors?
    I see one on the upper house in the back of the engine bay under the cowl, the same one in the engine block under the EGR and another one the is secured by a clip in a black rubber hose around the same area.
    Was wondering if anyone can confirm that. I found the service manual to replace the one in the back under the cowl, but I can't find info on the others. I found the part numbers based on a diagram, but that's about it.
    Thanks in advance
  2. Mendel Leisk
    40,475
    Engine mount torque values in here I think, starting about 60 pages in:
    #2 Mendel Leisk, Dec 27, 2024
  3. Soobz
    Soobz Junior Member
    LA, CA
    I
    Thanks Mendel I appreciate it,
    im gonna enjoy going through this hehe
