Right inner drive shaft boot looking oily
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Mar 21, 2011.
  1. Mendel Leisk
    38,734
    Had our Prius up and wheels off over the weekend to take off the snow tires, and noticed the right inner drive shaft boot is a bit oily. It's got me re-thinking the first service interval (Canadian schedule: oil change plus a few other items, at 8000km/6mo): rather than DIY I'll likely bring it in. The dealer is offering this first service for free.
    I'm leary of letting them near the car, will be vigilant of oil grade, overfilling, tire deflation, grease slopped on door hinges, bent-back maintenance door, and so on, but: I want to get my foot in the door with them, have them check this boot condition out. Leaking seal? Anyone else experience this?
    Meg&Bear likes this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Are you sure it was oil and not something else? Where you able to see above the shaft (as it might be something dripping from the engine)?
    So far mine is dry all around. Hope you don't have anything serious going on.
  3. Mark57
    2,945
    2,736
    OK
    I just did my 30,000 oil change. I always look at the boots when I'm under there and mine are clean and dry.
    Is it like an oil, or more like a light grease? Is it slick or gooey to the touch? Boot grease is thicker than oil and is gooey. Take some paper towels and carefully wipe the boot clean without deforming it to much. Then drive it for a day or two and check it again.
    The only boot leaks I ever had on my 4Runner was when the boot clamp came loose on one end. The boot itself was intact. The clamps should not turn on top of the boot material. They should be tight. Be gentile.
  4. vnhk
    vnhk New Member
    106
    san jose
    Can you take a picture of it?
  5. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I don't know but I've gone over a curb (the same one!) twice recently while parking due to paranoia of someone dinging up my door, so I'm going to give mine a glance over soon (no lift available, so I'll have to get down and dirty).
  6. Mendel Leisk
    38,734
    I will try to get under there, and get the under cover off, or at least the maintenance flap down, over the next few days, for a better look and hopefully a decent picture or two.
    Till then, best I can describe it, looking in through the wheel well, the boot is more-or-less uniform oily looking. It does not appear to be major, ie: I didn't see any flung drops, or anything on the garage floor, though the engine undercover could be catching it all.
    My hunch is some seal is failing, allowing a slight amount of transaxle fluid to get past, which then migrates with the centrifical force, to coat the boot. It could be grease in the joint though, not 100% sure. I did reach through and touch it: it just felt oily.
    Again, will try to get under there and get a proper pic, but I'm too wacked from work, have to make lunches, and so on, tonight.
  7. vnhk
    vnhk New Member
    106
    san jose
    I used to have a little leak via timing chain cover, dealer replaced the seal, and seems to fix it so far. Maybe you can check it. It's facing the firewall on the passenger side, so it's hard to see, but you can touch and feel around. You can also look up from the bottom when you open the oil change plastic cover.
  8. Den49
    Den49 Member
    498
    268
    Maryland
    The seal you suspect is the "Transaxle Assembly Type T Oil Seal" in the transaxle case. It seals the hole where the drive shaft enters. You have to pull the axle to replace it. It is a major job. The dealer may tell you that some seepage is normal, but if it seeps now it will leak later and needs to be replaced.
    On the other hand, if an axle boot is leaking, the boot needs to be replaced because it will also just get worse over time and will eventually cause the CV joint to fail.
    Good luck with the dealer.
  9. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    While changing my oil several times I noticed my CV boot was a little greasy looking and this seems to be the normal. No leaks or oily drops anywhere.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    So far after 25k miles, everytime that I have changed oil and/or transaxle fluid and checked my CV boots they have been dry all around.
    Let us know what you find.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    My right hand inner drive shaft boot looks a little shiny as if there is a waxy coating on it, no signs of any leaks or flung oil anywhere.
  12. Mark57
    2,945
    2,736
    OK
    As you feared, if you just take it to the dealer as is, you may get a new boot whether you need one or not. It probably is the boot from your description but I'd want to check closer if it was mine.
  13. Mendel Leisk
    38,734
    I'm going to have a good look tonight. Per KITHMO, it could be something like different boot suppliers. That would be a relief to me. I will check it out ;)
  14. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Pics please :)
  15. wigwag
    wigwag Junior Member
    CA
    I noticed what I think you are describing on both of my inner boots- the outers are bone dry. It's a very light coat of slightly sticky greasy-oily-waxy smutz. I found no sign of leakage from the joints or anywhere else making me suspect that this goop was deliberately applied. My idea was to clean it off thinking that it might attract dirt which would abrade the rubber but I got distracted and forgot about it until the car was off the jack and then I was too lazy to jack it back up. I'm just not as anal as I was in my younger days- the dumb goop will just have to whirl around until the next time the car goes up in the air for something more important.
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ it sucks getting old. lol
  17. Mendel Leisk
    38,734
    Well, I'd check it out tonight, except my better half is off to some horse & circus extravaganza downtown tonight. No Circque de Soleil for the pit crew... :rolleyes:
    Just from what I've hearing, it may be ok: either something intentially applied, or difference in finish of the boots. I obviously hope that's the case.
    When I get the chance I'll have a close look. I've booked a service appointment for Thursday, so better get to it by tomorrow night.
    BTW, thanks to all for the feedback! This site is a great resource.
    Update: Had a good look this morning, with the maintenance door pried open: total false alarm, everything dry, no leaks. Just a shinier, cleaner boot, as some responders had mentioned. ;)
  18. Mark57
    2,945
    2,736
    OK
    Cool, that's great news!
  19. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Glad to hear no problems.
  20. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    just saw my mechanic this afternoon and he tells me i need a new driver side drive shaft boot. apparently my old one is leaking. anyone knows the part number for this??
