Right side headlamp replacement
Discussion in 'Gen 3 Prius Main Forum' started by 67tony, Aug 8, 2015.
  1. 67tony
    67tony Junior Member
    36
    Michigan
    I'm having a difficult time re-inserting this lamp holder on my 2010 Prius.
    There is very little room, and I just can't seem to get it squared up and quarter-turned securely.
    Any suggestions?
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    If you mean the passenger side, then yeah, it's a PITA to reach. Take off the 10 mm bolt holding the air intake hose off, take out the plastic clip further down and bend the intake hose out of the way.
    If you still need more room, then remove the bolts holding the washer reservoir and move it out of the way.
    #2 xliderider, Aug 9, 2015
  3. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Yeah, I have had one LED parking light bulb and two led parking light bulbs on the driver side pop off before I could get them twisted in and never to be seen again it's getting kind of expensive I'm going back to losing regular bulbs.
