Right side turning signal not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pete4545, Jul 22, 2020.
  1. Pete4545
    Pete4545 New Member
    Orlando
    I
    I have a 2010 Prius where the front right side and rear right side turning signals are not working. The turning signal light inside the dashboard also does not show the arrow, however the left side turning signals are working. I have replaced the bulbs on the right side and have checked the fuses as there are no blown fuses. I also tested the bulb socket and there is no electricity. Does any one know what could be the problem? Anything would be much appreciated.
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Check you turn signal relay then turn stalk next.
    Montgomery likes this.
  3. Pete4545
    Pete4545 New Member
    Orlando
    I
    Great Thank You. I bought the relay hopefully that's the problem.
    49,469
    check the continuity on the fuse
