right tires for a good MPG
Discussion in 'Gen 2 Prius Main Forum' started by JCorrea, Sep 1, 2015.
  1. JCorrea
    JCorrea Junior Member
    San Francisco, California
    Hi all, just got my commute change stating next week or two .. 120 miles daily (6 days, both ways) so I got myself a 2007 Prius Touring with 105k miles very nice has all the bells & whistles, also I as able to score 4 black rims from a 2012 Prius (personal taste),
    did most of the maintenance spark plugs, fluids engine/trasmission, breaks etc
    .. but car need tires, now .. my goal is MPG, ...... The question, after checking online the tires opition for the 15" rims are - 175, 185 or a 195 ... can anyone tell me which tire choice will save me more in fuel.
    Kids call her Marshmallow .. :))))
    Thanks in advance
    Correa
    49,605
    michelin energy saver a/s.
    Data Daedalus likes this.
  3. JCorrea
    what size .... 175, 185 or a 195?
    49,605
    whatever is already on there, 195?
  5. dolj
    dolj Senior Member
    7,710
    3,903
    Wellington, New Zealand
    The OEM spec for the 2007 is 185/65/R15, but in the UK the 16" rim are fitted with 195/55/R16 and here in NZ we fit 195/55 R15 on 15" rims. I'm not sure what effect the wider tires would have, but of much greater importance is getting tires that have low rolling resistance (LRR). As the name implies an LRR tire will roll further before it stops due to a lower resistance.
    The Michelin mentioned by Bisco is one that comes up a lot. Other manufacturers also make LRR tires:
    • Michelin Defender
    • Bridgestone Ecopia 422 Plus
    • Continental TrueContact
    • Continental ContiProContact
    • Goodyear Assurance Fuel Max
    • Goodyear Assurance ComforTred Touring
    • Yokohama Avid Ascend (T-Speed Rated)
    The Goodyear Integrity are the OEM tire, but not a lot of people have anything good to say about them.
    If you want opinions about any of these tires do a search in the Gen II Fuel Economy forum using any of the tires listed above and read until your eyes hurt.
    Once you have your new tires fitted, be sure you run them 4-6 PSI higher than the door placard (35F/33R) so at 39F/37R - 41F/39R. Any higher than this yields diminishing returns in my experience.
    Hope that helps.
    #5 dolj, Sep 1, 2015
    05_silver likes this.
  6. dolj
    dolj Senior Member
    7,710
    3,903
    Patience, grasshopper!! (y)
  7. Mendel Leisk
    38,795
    Look on TireRack. You can set it to show only LRR.
  8. JCorrea
    thank dolj ......... what an explanation ;)
    I have a 185/65/15 now, some shops is telling me i can go up 195/55/15, .... going to look at LRR
  9. dolj
    dolj Senior Member
    7,710
    3,903
    That would be correct.
  10. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    185 Michelin Energy Saver A/S. We consistently knock down 50+mpg in mixed driving conditions inflated to 42F/40R. This car does 100+ mile daily commutes most of the week as well.
  11. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    195, bigger, better mpg's
    More accurate speedometer
  12. Mendel Leisk
    38,795
    I wouldn't do ANY of the above.
    douglasjre likes this.
  13. Lucifer
    1,014
    485
    Nh
    Anyway, to answer the op's question, the 195's will save more fuel, what of the above btw, wouldn't YOU do?
  14. Mendel Leisk
    38,795
    The stock tire width is 185. Going to a wider 195 tire will invariably lower mpg.
    Speedometers read slightly high due to international agreements, in the hopes of slowing drivers down a bit. Odometers however, are accurate. Going to larger outside diameter tires to "correct" the speedometer seems overkill, and it will cause the odometer to read low. Larger tires will also be more expensive, and (albeit only slightly) reduce wheel well clearance.
  15. Lucifer
    1,014
    485
    Nh
    Ah, I see
    Yes the width of the 185 is 7.4 inches vs 7.9 inches for the 195, the 195 has a 25" circumference vs the 24.5" circumference for the 185 series tire, I'm saying the 195 gives better mpg's because of the larger circumference, irregardless of the 1/2" larger width.
    And the speedometer is almost exactly correct.
    But...I'd be interested in seeing unbiased comparisons.
  16. CooCooCaChoo
    CooCooCaChoo Senior Member
    903
    505
    Cow-lee-fornia
    2023 Prius
    Not to mention probably even heavier and thus contribute more to unsprung weight.
  17. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    Increasing the rolling circumference in a manual car can improve mpg by reducing engine revs for a given speed. With the Prius transmission this is not the case as engine revs are likely to increase with an increase in torque load that a larger circumference will produce
    John
  18. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    A 55 is a wider tire than a 65 for a given diameter. Typically, narrower tires give better mileage and poorer handling. If you drive typical Prius style, hypermiling and such, I'd select one of the LRR (low rolling resistance) tires in the 65 profile. If the recommended tire is a 195/55 then you could go to a 185/65, which should keep the diameter around the same while narrowing the thread footprint. I use the Bridgestone Ecopian 422 in the factory recommended size on both the Prius and am now putting some of them on my Odyssey van. I get around 59 in the summer and 45 to 50 in the winter, typically never exceeding 65 MPH. Again, this slightly reduces cornering and stopping effectiveness because you have less rubber meeting the road, the reason for the increased economy. The LRR tires accomplish similar by staying "rounder" (they are stiffer in the sidewall), I understand. Others may elucidate a bit more.
  19. Mendel Leisk
    38,795
    Assuming 55 and 65 are tire profile heights (the number after the slash) I think you jumped the tracks there. Not 100% sure, the coffee hasn't kicked in yet. Take tire designations:
    195/65R15 and 205/65R15
    The second's wider than the first is all.
  20. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    I agree. Same profile, bigger size. The second is also taller. (The 65 is a percentage of height vs. width.) But if you compare a 195/65R15 with a 195/55R15, the second one is again wider (and also shorter). Make the first a 205/65R15 vs 195/55R15 and I believe that they will be around the same diameter with the 55 still wider. Do we need a tire person here????
