Rim off set question.
Discussion in 'Prius c Accessories and Modifications' started by Christophers, Sep 8, 2018.
  1. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    I’m quite unsure what’s the lowest offer our cars can go with clearing everything in the front wheel well. I’m shooting for a 16x8. My car is lowered but it’s its tasteful. Thinking a +25 May clear but considering a +15. If anyone can help please do.
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Fair warning, I had wisdom teeth pulled the other day, and I'm still on happy pills, so maybe I'm just not able to wrap my brain around this, but I don't see that fitting without mods.
    I'm on 16x6.5 with a 37mm offset. Tires are a 205/50/16 so same height as stock. I'm lowered on RSR springs and TRD short stroke shocks. The back 1/4 panel had to be modified for clearance and I still ended up adding negative camber to keeping from rubbing all the time. Front rubs at full steering lock on the frame and wheel well liner, and rubs the liner on large bumps at speed.
  3. Mendel Leisk
    40,574
    Get off those asap man. :LOL:
    No seriously, don't get liking them.
  4. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    lol I'm not even 48 hours since the surgery. And even after the surgery I didn't take anything until the shots wore off to see if I could take the pain. Trust m a drug addiction is not in my future. I can't afford one with the car and camera addictions already!
  5. Mendel Leisk
    40,574
    Yeah usually when I got that subscription, the codeine laced one, I'd take one, to "celebrate". The last few times I told them not to bother, I've still got the old pills. And I'm trying to ignore them...
    The secondary "reward" with that stuff is constipation...
    Mostly I'd just try aspirin or Tylenol. Even that seem kinda pointless: there will be pain. And you look like a chipmunk, such is life, lol.
  6. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
  7. Mendel Leisk
    40,574
    Yes, apologies, I should know by now. :oops:
