rims from a gen2 onto a gen4, safely yes or no?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by prius_deep, Oct 21, 2018.
  1. prius_deep
    prius_deep Member
    105
    38
    road
    PRIUS BOLT PATTERN
    2008, 2016
    bolt Pattern 5x100 mm
    Hub Bore 54.1
    Nut or Bolt nut
    Nut Bolt Thread Type M12x1.5
    Nut Bolt Hex 21
    Nut or Bolt Torque 76*
    I tried last year to get Nokian WRG2 for the 2016 but the Nokian site said that they did not make that tire for a 2016 prius?! So I went with the Michlein x-ice for the 2016.
    and Nokian WRG3 for the 2008 , was told by tire place Nokian WRG2 were no long made.
    So if the rims of a gen 2 can fit on a gen4 why can’t the same tires be fitted on a gen 4??
    Gen1:
    Bolt Pattern 4x100 mm
    Hub Bore 54.1
    Nut or Bolt nut
    Nut Bolt Hex 21
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Although the bolt pattern may be the same, there are other considerations like offset and rim width. Offset has a significant impact on interference for brakes and suspension components. If the bolt patterns, rim width and the offset are identical, then they should be interchangeable.
    Tande likes this.
  3. Tande
    Tande Active Member
    525
    310
    Mich.
    Can't remember for sure (I had one :confused:), but didn't the Gen.2 have 14" wheels??
  4. prius_deep
    prius_deep Member
    105
    38
    road
    thank you, knew there had to be a reason.
    thanks.
  5. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Gen 2 standard rims are 15" and the touring model rims are 16". I don't remember the rim widths so I'm going to leave that to someone else.
  6. Tande
    Tande Active Member
    525
    310
    Mich.
    Thank You......I stand corrected......
  7. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    You can use this link to compare OEM rims from various years of prius. Go to the bottom of the page to select what year you'd like to see. Shows specs for ALL models, US, Europe, Japan markets
    Toyota Prius 2007 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
    It looks to me that the 2008/2016 rims should be interchangeable.
    The difference is the 2016 uses a 195/15 tire and the 2008 uses a 185/65 tire. Many tire shops will refuse to install a tire that doesn't match OEM, so that may be some of the problem...the difference between a 185/65 and 195/65 tire is about 1/2 inch of height (195 will be 1/2" larger diameter) which will affect MPH reading
    Personally, I don't see any issue with installing the 195/15 onto a 2008 rim.
    If using 2016 size tires on a 2008, you'd need to make sure there's no rubber rubbing when the steering wheel is at max rotation each direction and your mph reading will be slightly lower due to tire having less revolutions per mile..
    If installing 2008 sized tires on a 2016, your mph reading will be slightly high, since the tire will have more revolutions per mile.
    #7 TMR-JWAP, Oct 21, 2018
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    What condition are the 2008 rims in? You don't identify what country you're in - that could make a difference to your local regulations. Though the tyre shop should be able to guide you.
    I'm not sure of the life-span of an alloy rim - it could be worth enquiring.
    The other thing to consider is keeping the 2016 rims for when you sell the car, to return it to original. Someone might get upset if you sell it to them in 6 years time to discover that their rims are 16 years old.
    Do you have TPMS?
  9. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    The 185 and 195 numbers are the section width of the tire in mm. So the 195 tire will also be 10 mm wider than the 185, thus the concern about rubbing on the car that was spec'd for the 185 tire.
  10. Rmay635703
    Rmay635703 Senior Member
    2,647
    1,670
    Somewhere in Wisconsin
    2013 Chevy Volt
    I’ve mounted full size tires on space saver rims before, even fairly significant changes don’t have much affect on rubbing so long as the offset is adequate .
    In fact narrower rims reduced the “bald edges on front tires” issue I was having on one car.
    And It’s not like he is putting LT Inflation tires on his car, going one size up or down is moot, MPG hit would likely be under 5%
  11. prius_deep
    prius_deep Member
    105
    38
    road
    Just asking because I have been visiting junkyards to see if I can find rims for a 2016. So I can have both the ~summer tires~ , and ~winter tires~ mounted on rims, and I change my own tires; and not keep paying the $80 in the future.
    Again thanks for the replies. Looks like it's going to have to be a 2016 wreck.
    krmcg likes this.
  12. alanclarkeau
    7,045
    7,589
    Someone mentioned that they used Corolla rims, steel I think, for winter tyres. Double check that it was a Gen 4 they were talking about - or try one at a wrecking yard.
    If I end up on an around Australia drive, I'll investigate the Corolla wheel as a 2nd spare.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    All UK Gen 2s have 16" rims.
    I know the Gen 3 17" rims fit on a Gen 2.
    Redirect Notice
  14. Mendel Leisk
    40,586
    Yeah this 15" rim works, on 3rd gen, and I would suspect 4th gen as well:
    Corolla steel rim, part no: 42611-02471 (2003-2008 corolla or matrix, CE, LS, S)
    steel rim lug nuts, part no: 90942-01007 (plain, open-ended, galvanized)
    For me in 2010, the rims were $70 (CDN) apiece, and the set of 20 nuts was $31. I'm not that enamoured of the nuts though: they don't have shoulders, so it's easy to damage the rim paint with a socket, and they're open end, making the stud tips rust prone. I put a drop of oil on each, that helps.
    I use a 2" ABS end cap to cover the hub opening: with a rubber band (cut from old bicycle inner tube) pushed over the hub flange, it's a slight interference fit. Without a cover the hubs rust up very quickly, Toyota rustproofing sucks.
    Nothing fancy:
    #14 Mendel Leisk, Oct 25, 2018
    ETP and alanclarkeau like this.
  15. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Is this the best way to go????? Also what size tire do you need?
  16. Mendel Leisk
    40,586
    It's worked for me, same tires for 9 years now, just the stock 195/65R15 size.
