  1. Golf cart 1
    Golf cart 1 New Member
    US
    What is a good size rim to put on a 2006? Will a Scion rim fit with no problems or MPG loss? Thanks for any help.
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Not many rims have as low weight as the oem 15" or 16" wheels. So, many will fit, few will not cause MPG loss...
    Most wheels are worth the loss of mpg as the oem wheels are quite ugly...
    marvingloria2011 and Golf cart 1 like this.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The older Gen Scion Tc rim have the correct bolt pattern, the newer Scion rims went to a different bolt pattern.
    Golf cart 1 likes this.
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    imho, 17x7" wheels would be the best compromise. if you go beyond that- or use a tire wider than 215- you likely will need to modify the wheel openings. I would look for at least 45mm back spacing too.
  5. Max Finch
    Max Finch Active Member
    135
    131
    Medford Oregon
    5x100 bolt pattern +45 offset are the Touring. Probably the same as stock
  6. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
  7. Max Finch
    135
    131
    Medford Oregon
    Here’s a bunch of lightweight 16’s and 17’s. There’s some 15’s and 18’s in there as well
    Wheels for 2008 Toyota Prius Touring
    Edit: link doesn’t apply my weight filters :/
  8. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Gen2 Prius
    15 inch 14.3 lbs
    16 inch 15.2 lbs
    Gen3 Prius
    17inch: 24.3 lbs
    15inch: 16.3 lbs
  10. NortTexSalv04Prius
    915
    115
    Thanks
    How did you come by this data?
    Do you know the weight on Gen 4 OEM 15 inch?
    What benefit have you achieved with that ceramic header on your mod Gen2?
    Thanks in advance Just did It
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    The info has been posted in threads b4, I just searched and reposted.
    Gen4 wheel specs I haven't seen yet.
    When I still had my Gen2, the header greatly improved exhaust flow in the higher rpm band - Improved battery regen time and felt easier to pass on highway when electric was worthless. From stoplight to stoplight, the electric motors helped with any torque loss due to a higher flowing exhaust.
