Road Noise- revisited
Discussion in 'Gen 4 Prius Main Forum' started by Donkro, Apr 5, 2022.
  1. Donkro
    Donkro Junior Member
    Chicago
    2020 Prius
    I know this topic has been discussed, but as much as I like this car, the road noise is really bothersome. I'm looking at options of new tires, sound deadening of either wheel wells, floor, etc. I'd like to hear from those of you who might have done some of this and what gave you the most bang for the buck?
  2. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My son-in-law had sound deadening installed under his carpeting in a Gen2 Prius. It made a noticeable improvement in the road/engine noise, but not a significant one. I measured the difference between his and my 2004 Prius (no sound deadening material) at about 4 dB.
    JeffD
  3. Mendel Leisk
    38,873
    IIRC 4th gen is supposed to be a little better than the previous gen's.
    49,693
    probably came to prius from a real car
  5. dacoobob
    dacoobob Member
    83
    45
    Kansas City, MO
    Four Touring
    It's all relative to what you're used to. My gen4 Prius is significantly quieter than my previous vehicle (a Hyundai Accent).
  6. dmanthree
    dmanthree Junior Member
    36
    Massachusetts
    Question: is the Limited trim quieter than the other trims? Is road noise still an issue on that tri?
  7. PaulDM
    PaulDM Active Member
    616
    318
    UK
    2022 Prius
    Excel
    No question. The 2016 and 2019 both drive quieter and more responsive than a gen 1 or 2 or 3
  8. AzWxGuy
    AzWxGuy Weather Guy
    986
    497
    Tucson, AZ
    2021 Prius
    I can compare my '21 Limited to a '11 trim 3 and say it is much quieter. I noticed this on the test drive. It is such a subjective area though. I have a moderate hearing loss corrected with hearing aids so I'm a little more sensitive. And infrastructure improvements in my state, road work in particular, is proceeding at a rapid enough pace to eliminate most of the washboards I've been driving over. Tire quality and age, and inflation pressure can make a difference too. If it's a really bad road I do the Click and Clack thing and turn up the stereo.
  9. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    I put sound deadener on the trunk floor. While I do believe it changed the car's sound, I don't believe it was worth the effort.
    Pulse07 likes this.
  10. Pulse07
    Pulse07 Active Member
    273
    139
    East Bay, California
    2020 Prius
    XLE AWD-e
    I think its called turning the volume up.
  11. Tideland Prius
    16,195
    Yeah but a Corolla of the same generation as the Gen 3 is quieter than the Gen 3. I haven't sat in the latest Corolla vs. the Gen 4 but I'd imagine it's at least as quiet, if not better than the Prius.That was my complaint with the Gen 3.
    It is. The Limited gets acoustic front door glass (double pane) vs. regular windows on the LE and XLE.
  12. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    My 2016 is much quieter than my previous Mazda 3. It's all relative to what you're used to.
    dacoobob likes this.
