Road Noise
Discussion in 'Gen 4 Prius Main Forum' started by smalltimeart, Feb 24, 2017.
  1. smalltimeart
    smalltimeart New Member
    22
    Four Touring
    I'm sure everyone here has noticed the Prius isn't exactly the quietest car. I'm looking to Dynamat the interior to deaden some of the usual road noise. Does anyone have any suggestions as to where most of the road noise comes from? I'm assuming I should start underneath the carpet and eventually work my way up. Anyone have any thoughts or what they found worked?
    52,363
    i haven't done it, but some with gen 3 have started with the hatch bottom and wheel wells. also, better tires will help, but expensive.
    RCO and alanclarkeau like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I wonder if the ECO type tyres might be contributing? Not sure how you correct that. I would wonder also if the bulk of noise at speed isn't just road noise, but also wind noise. Which sounds odd on a car with excellent aerodynamics. Like all cars, it's built for a purpose as well as a price. To make it as quiet as a Rolls Royce, you'd end up with lots and lots of sound deadening, have to rebuild panels thicker and install thicker glass. All of which would add to the weight substantially.
    I'd suggest just drive it the way it is. But if I did want to start with deadening, I'd try putting something like a mattress or a pile of cushions in the boot (trunk/hatch) area and see whether that's the noisiest part - I'd suspect it is.
    I don't find PRIUS particularly noisy - it's quieter than my last 3 cars (2006 KIA RIO, 2008 FOCUS Diesel, 2011 FIESTA Diesel) - particularly at rest ;). And in slow speed city driving, it's superbly quiet.
    RCO and iamvietdang like this.
  4. smalltimeart
    22
    Four Touring
    It's a Gen4 Touring (don't know if that makes a difference, possibly the fact that it's got the 17" rims) I've noticed it's mainly wind noise oddly enough. There's also some road noise in there but it's just kind of noisy overall. It's definitely not a deal breaker but just something i'd like to take on as a project and see if i can improve upon. I'll probably start with the flooring carpet and work my way up.
    I'm not too concerned with adding some extra weight. I'm a service tech and drive around 3k miles a month with a bunch of not so light tools and still manage to get fantastic gas mileage. It definitely is quieter than a solid diesel :p.
    blazedlawyer, RCO and bisco like this.
  5. alanclarkeau
    7,045
    7,593
    It could also be a relative thing - because I don't hear the sound of a diesel/petrol engine going up and down the gears, I suspect that the next most obvious noises will "be obvious".
    A bit like home - when the children go to school, you tend to hear the lawnmower from 2 doors away, the postman's bike in the next street and the traffic noise from 100 metres away - because there is no children chatter and clatter.
    Don't try too hard - they tell me that total silence isn't a pleasant experience.
    Absolu22, RCO, kithmo and 1 other person like this.
  6. smalltimeart
    22
    Four Touring
    That's very true. I'm mainly trying to avoid turning up the stereo while i go up in speed. (you think toyota would have the head unit capable of that) I'll have to do some experimentation. thanks for the input!
    RCO likes this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I thought my Gen 3 was noisy (17" rims), noisy enough to make me trade it in for a Prius+ (17") which was very quiet, probably due to the 3rd row of seats acting as sound deadening. My gen 4 (17") is somewhere in between, but much quieter than the Gen 3. The quietest Prius in the family is SWMBO's Gen 2 on 16" rims.
    reallyreal and RCO like this.
  8. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    I think you are spot on starting with the floorboard under the carpet.
    Don't forget the firewall.
    As for thoughts, wheel wells (dyno inside the removable fender liners) would be second.
    I have a v and I notice the roof is thin metal and echos the rain drops from the latest storms we are having in Calif.
    This is truly loud.
    Dynoing under the headliner could be a good option.
    Have fun.
    RCO and smalltimeart like this.
  9. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    In the spring when I make a purchase, my plan is to start in the rear area. It should be a simple task to install Dynamat beneath the carpet. many have written how much quieter the interior is with the luggage curtain closed, so that seems to be where a lot of road noise is coming from.
    Dynamat in the doors would be a real chore.
    Based on my experience .... I believe the tires are a large part of the problem. In my 2010 Prius, the noise was reduced significantly when I changed from the OEM to Michelin Energy Savers.
    bisco and RCO like this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My early (2012) Uk Prius+ (v) T-spirit had a polycarbonate panoramic roof, which was very quiet.
  11. first_superior_prius
    76
    115
    Michigan
    I don't know what kind of cars you guys were driving before the Prius, but I find the Prius to be extremely quiet compared to many cars. Has anybody used a decibel meter to quantify?
    I notice more wind noise in the Prius than other cars, but I think it's because the engine and tire noise is a lot quieter than other cars, so you just notice the wind noise more.
    RCO, alanclarkeau and Absolu22 like this.
  12. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I used a decibel meter on my VW Jetta and my Prius 4 on the same piece of road and at as close to the same speed as I could using GPS to measure. The VW was ~58 dB and the Prius was ~53 dB. So, it is a pretty minimal difference.
    RCO likes this.
  13. bisco
    52,363
    it's definitely subjective when you talk about comparison's to other cars, but almost any car can be made quieter. unfortunately, there are side effects to doing so.
  14. Tideland Prius
    16,611
    6 dB is quite a bit of a difference. I would think a person of normal hearing should be able to hear a difference of 6dB, no?
    ice9 and alanclarkeau like this.
  15. Prodigyplace
    12,665
    11,828
    Central Virginia
    I believe the original standard for 1 dB was the amount of change barely detectable by the human ear.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    on a logarithmic scale 6dB is a 50% drop in sound.
    ice9, RCO, alanclarkeau and 2 others like this.
  17. Tideland Prius
    16,611
    Yeah so that should be noticeable.
    ice9, RCO and alanclarkeau like this.
  18. bisco
    52,363
    i don't trust these meters, or more specifically, the method of testing.
  19. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Felt - please correct me if I am wrong - you do not even own/drive a gen 4 Prius. But you want to modify the (future) car due to road noise?
    My 4 touring is very loud over certain road surfaces, and crystal clear silent over new or other pavements I think the Toyota engineers did a great job with soundproofing this car; the floor, roof and pillar assembly, door panels, windows (double pane) and other outside areas. But road road noise rumbles into the cabin over rough pavement, I think through the tires, into the steering column, and the dashboard. I also heard various noises reverberating inside the dash (see my other posts) and sometimes the door panel.
    roadwarrior28 likes this.
  20. Prodigyplace
    12,665
    11,828
    Central Virginia
    Minor correction. It would not be able too travel through the tires into the steering column because they are not connected. The Prius is drive by wire.
