road noise
Discussion in 'Gen 3 Prius Main Forum' started by PDM49, Jul 19, 2010.
  1. PDM49
    PDM49 New Member
    Considering a 2010 or 2011 Prius. Prius owners, do you have complaints about road noise?
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I don't, YMMV.
    They do have more road noise then some cars, less than some other cars.
    Test drive one and decide for yourself. It will be worse on concrete than asphalt, the rougher the concrete the nosier it is so look for a concrete road for your test.
  3. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    It depends on what kind of vehicle you are coming from. I came from a big truck so this is like a town car. If your coming from a higher end car it is going to be more road noise then you are used to.
  4. xlr8me
    xlr8me New Member
    va
    naw, its not bad at all. I have blutooth and conversations are very easy at any speed.
  5. bisco
    49,446
    and supposed to be quieter than my gen II!
  6. andino
    andino Senior Member
    746
    550
    San Jose, CA
    If you're coming from a luxury car, it'll be louder. Its about on par with other cars in its class. Its a bit quieter than my last car (Scion tC)
  7. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    I've also heard that the V is louder than the others, since there's less rubber cushioning you from the road. Never compared it myself, though, and it doesn't bother me. The reduction in engine noise sure is nice, that's for sure!
    Heck, that might be the main reason for any road noise complaint you might find; there's hardly anything else to be heard, and I feel like road noise is generally more objectionable than engine noise (which you feel is at least tied to your car, and somewhat under your control).
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Depends on the tires and the roads you drive on..... :)
    I've had 4 different brands/models of tires on my Prius so far and they all change how noisy the car is. The 17" performance tires were the worst followed by the stock Integritys. The db Super E-Spec and Nokian i3s were much less noisy.
    Like stated by everyone else, it really comes down to what you are used to in your previous vehicles.
  9. blue bird
    blue bird New Member
    Belfair, WA
    There is quite a bit of road noise, so much that the blu logic bluetooth that came with the car (but added at the dock) is worthless. I have been looking into how to dampen the road noise.
  10. kazak
    kazak New Member
    Austin
    I've only had the car for about 300 miles and my perception of road noise is minimal compared to my previous Spectra. It also seems quieter than my 05' Tacoma 4D but it's a truck. Compared to the '10 Civic, '10 Insight, and the '11 Sonata, it's probably the quietest. My old IS300 was probably the quietest car I've had.
    Now that I'm getting familiar with it, I do notice a bit of road noise. I haven't setup bluetooth yet on my iPhone but judging by other posters, I may not like the results. Overall, I think it is good. Maybe 3.5 stars out of 5?
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I have zero problems using bluetooth in my car but I do admit to using bluetooth through my Kenwood stereo and not the factory system. Maybe the problems stem from the bluetooth more than the vehicle noise?
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I am going to second the comment about the road and tires. The Prius is inherently a quiet car. It's not quiet because of sound insulation, it's quiet because it doesn't make much noise. If you drive on a noisy road or noisy tires you will hear it.
    Tom
  13. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Nope. And the 2010 imo is better (less road noise) than my 2006 was...
  14. Thai
    Thai Prius Neophyte
    1,197
    89
    I enjoy driving on the highway...and BT works flawlessly while driving. Road noise? Not a problem for me.
  15. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    My 2010 III was the quiestest car I've ever owned for the first 5,000 miles, then the dealer rotated my tires. Now it sounds like I have studded snow tires, and it is NOISEY. Turns out the rear wheels are way out of alignment, and those tires are cupped. I think I've become a believer in yearly alignments as recommended for the Prius by Toyota.
    The bottom-line is that the Prius can be a very quiet car if the tires are balanced and the front end is aligned properly. Those who claim it is noisey don't have things adjusted properly, IMO.
  16. qbee42
    18,058
    3,074
    Northern Michigan
    Or drive on noisy roads. Some road surfaces are a lot louder than others.
    Tom
  17. Thai
    Thai Prius Neophyte
    1,197
    89
    But this applies to every car. I have a road near my house that is quite noisy.......even in an Avalon, Lexus LS430, etc..
  18. qbee42
    18,058
    3,074
    Northern Michigan
    True, but it applies less to cars with heavy sound-proofing. Most luxury cars use copious amounts of sound absorbing materials to eat up road and tire noise. The Prius is pretty light in this area. Adding a lot of extra weight for sound control is contrary to the very philosophy behind the Prius.
    While the Prius has some sound deadening materials, most of the quietness of the Prius is inherent: The Prius makes little noise of its own. This is why a Prius is quiet on smooth roads and not so quiet on noisy roads. A good luxury car would be fairly quiet on both, but at the expense of gas mileage. While both would make road and tire noise, less of it gets into the cabin area of the luxury car.
    Tom
  19. Thai
    Thai Prius Neophyte
    1,197
    89
    Tom, yeah, i agree. On the road mentioned above by my house, there was a difference, but not a big difference b/w Prius and the Avalon and LS.
  20. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed.
    My previous car was a BMW, so the interior noise level is much higher in my Prius, and took a while to get used to.
    I listen to music most of the time I'm driving, so that helps a bit--though the interior noise does interfere somewhat with the sound quality of the music.
