roadshow: prius hid and winter gas
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by rigormortis, Dec 22, 2008.
  1. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    Roadshow: Cost to replace on-and-off Prius headlights can run $950 — or nothing
    By Gary Richards
    Mercury News
    San Jose Mercury News
    Article Launched:12/17/2008 10:23:30 AM PST
    Q I don't know if you've already discussed replacement costs for Toyota Prius headlights, but . . .
    Steve Armstrong San Jose
    A Oh, we certainly are today.
    Q We are a two-Prius family. Both cars have been dependable until recently, when my wife's 2006 car started experiencing problems with the headlights. Both started to go out alternately, and when she turned the light lever off, then back on, the lights would come back on for a few minutes. I took the car to the dealership, thinking it was an electrical problem and would be covered under the extended warranty. Wrong! I was told both headlights had to be replaced and were not covered under the warranty — at a cost of $381 each, plus approximately $200 labor. Total cost to replace both headlights even after a discount of 15 percent was $950.
    Steve Armstrong
    A Ouch! And . . .
    Q I bought a Toyota Prius in late '06 and have loved the car. Then in August I began experiencing failure of the left front headlight. It seemed to sporadically falter. Not long afterward, my wife was making a nighttime drive down a twisting back road in Aptos and the entire light system went out. I flipped the steering column switch and the lights came back on. I went to the local dealer from whom I purchased the car and the service rep said that individual lights cost about $350 each to replace. I indicated that it wasn't just the one light that was acting up. He responded, "Yeah, we've had Priuses with this problem." I told him that I wanted to talk to Toyota about addressing a problem that is a safety hazard and given the newness of the vehicle this should never happen. A person in the corporate office indicated that Toyota would not assume any fiscal responsibility for the repair. He reasoned that the 65,000 mileage was beyond the range of responsibility for this problem, and that I had not had my car serviced at the Toyota dealership. I argued that we weren't talking about a normal condition, brake linings and wear factor items. I told him that of the six Toyotas I have owned as well as the many other various vehicles, I have never known a car to simply have a total light failure, and that it was not a mileage-related problem, but a safety defect that they should address. The problem has gotten progressively worse and the lights fail constantly. I have been perplexed with what to do and pressed to find the extra dollars to take it in to the dealership and simply swallow the expense. Someone suggested I write you.
    James Hamilton Aptos
    A Full confession. This has also happened to my Prius, and I have heard from other drivers who have experienced similar problems. Some motorists, like Steve, have paid $950 to fix their lights. My dealer charged me for labor only, and others say they have not been charged at all to have their lights replaced. Toyota says it is seeing similar problems with high-intensity discharge (HID) bulbs, and this is not confined to the Prius. The corporate folks also say its up to each dealer to determine how much you should pay. That is a pretty weak response. Forking over nearly $1,000 to replace lights on a 2-year-old car is tough to swallow. Toyota recommends you call its customer center at (800) 331-4331 if your lights are also going out. Then let me know how Toyota responds.
    Q This isn't another letter to incite a riot about Prius/SUV drivers, just a simple question that no one can seem to answer. I figured you know the ropes, so: I had been getting about 48 mpg in my Prius up until the last three tanks of gas, and my mileage has fallen to 43 mpg. My driving habits haven't changed, so I thought maybe it is the California winter gas. Can mileage be reduced by 6 to 10 percent?
    Stephen Schrag
    San Jose
    A Yes, it can. It's a combination of California's winter blend of gas, which affects all cars. Plus the Prius mileage tends to drop in cold weather, when the gas engine kicks in more often. My mileage has fallen from 54 to around 48 mpg.
    Contact Gary Richards at [email protected] or (408) 920-5335.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Can HID headlights be replaced with inexpensive alternatives ?
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    $381 for just the bulb or the bulb and ballast? There's a reason why I prefer halogens in my vehicle.
  4. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    This sounds like a fundamental electrical wiring problem, rather than a defect in any one of the headlights per se.
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    The HID bulbs are around $250 from your friendly Toyota stealer, er, dealer. You can purchase them online for around $100 each. Installation is expensive, as it's not easy.
    They are "arc discharge" bulbs and do wear. When worn they tend to "go out" (arc extinguishes on its' own). You have to cycle the power to get the electronics to restart them. Not so much a wiring problem, but rather perhaps poor electronics design. It should detect if they go out and automatically restart them. Then send a CAN message that it's time to replace the bulb.
    Now I too am happy we only have Halogen bulbs in Canada. They work just fine, thankyou. And cost about $10 each. Maybe less, if you shop around.
  6. SureValla
    SureValla Member
    590
    Shelton, CT
    I had the headlight problem at 35k miles and the dealer replaced both free of charge
    Theres a whole 30 page thread on the headlight problem and people's various solutions. If you pay money your doing something wrong warrenty or no.
  7. GatorJoe
    GatorJoe New Member
    56
    this is happening on my Prius. has been since i got it. it isn't always the same headlight either...guess ill need to take it in.
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    I wouldn't touch HID's with a ten foot pole. The last time I changed a headlight was about 4 years ago on a then 10 year old Accord, might have been the only one I changed on it. It was so cheap that I don't even recall the cost.
  9. johnjohnchu
    johnjohnchu Active Member
    211
    104
    on/off HID light issue is well documented in Priuschat. Bulbs can be obtained for less than $100/pair via eBay. Replacement is a little bit involved, estimated 15 minutes per side.
  10. DavidA
    2,342
    1,818
    Chicago western burbs
    Ouch! I first heard of the HID problem as I was shopping for my GenIII. An older gentleman was looking at the same Prius in the showroom and we struck up a conversation. It turns out that his GenII had just come out of the shop with an $800 repair bill for the lights. He was selling the car. I asked what he was looking at to replace it and he remarked "A new Prius of course!"
    We were both convinced at that moment to step up to the V, as that level comes with LED headlights. (the brights are still HID in the V)
  11. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    I have a V and I believe the brights are Halogen, 9005/HB3 according to the manual (p.567).
