Rockerdan's Plug-in thread
Discussion in 'Gen 3 Prius Accessories and Modifications' started by rockerdan, Sep 14, 2012.
  1. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    I got my new Plug-in base about 1 month ago(Aug 11th) and thought i would post up some of the basic mods Ive done so far.....
    Mods so far
    -OEM 'Plug-in' all weather floor mats (winter)
    -OEM 'Plug-in' carpet floor mats (summer)
    -Hardwired radar detector
    -Custom Nav Visor
    -Window tint - Sides 35% / Hatch 20%
    -Window vent visors
    -Speed lock override
    -Xenonsupply 6000k HID headlamps
    -Front plate relocate
    -Bumper Plugs
    -Lamin-X tails 17%
    -LED Rear Plate Bulbs (Xenon white)
    -LED Front Parking Bulbs (Ultra blue)
    -Wheel Spacers (22mm Rears, 10mm Fronts)
    Day one,picking it up at dealer
    Winter "Plug-in" Mats
    1st mod...I made a Nav Visor/Hood
    Window Tint (35% sides, 20% hatch)
    Window Vent Visors
    Speed Lock Override
    able to do a Slideshow on the fly if you want!
    HID headlight 6000K (xenonsupply)
    Right side HID, left side Stock
    HID 6000k, both sides done
    Cutoff line
    6000K at night
    Front Plate relocate, Bumper Plugs (winter gray)
    LINK: Order Form
    Lamin-X Tails (17% "smoke")
    Front Parking light LED bulbs (Ultra Blue)
    Comparison Pic
    Rear License plate LED bulbs (Xenon white)
    Comparison Pic
    Created Playlists on USB stick
    Wheels Spacers (22mm rears)
    This type just bolt right on, very simple!
    Makes the car look so much better, no more sunk-in rear wheels
    Wheel Spacers (10mm fronts with longer studs)
    remove caliper and rotor
    Drive out studs using a socket and extension
    Install new longer studs
    tighten each stud in place with lug nut and something to take up space when tightening(can use stack of washer or a oversized crows foot as shown)
    Install rotor, Caliper and new spacer onto new longer studs
    Stock PiP Wheel/Tire weight (37.5lbs)
    Spacers DONE!
    Spacers before and After (22mm rear / 10mm front)
    49,359
    well done, thanks! amazing how it looks black in some lighting.
  3. rockerdan
    427
    83
    Wheatfield NY
    thanks! I love this car!
    Getting 125MPG overal so far at about 1000 miles on ODO....this was taken at my first fillup at one month old.
    peterjmc likes this.
  4. ePrius
    ePrius Member
    162
    76
    Awesome mods! Looking good!
    What's next?
    Where did you get the spacers?
    Thanks!
  5. rockerdan
    427
    83
    Wheatfield NY
    I just put up the links near pics. The spacers I got off ebay, there are much more expensive ones out there but these are hubcentric and that was my main goal. They are very nice and ZERO vibrations.
    I think the minimum size with built in studs is 15mm. I think 15mm might be abit too big for fronts, but if you like the "poke" look you can save alot of time by using the ones with built in studs. The built in studs type just slap right on, no need to change studs. My rears 22mm only took 5 mins to slap on, while fronts without built in studs took about 25mins since you need to remove caliper,rotor and studs.
    I think the 22mm rear/10mm front looks perfect.
    But man oh man the car looks soooo much better with wheels closer to flush, especially from behind!
    Dan
  6. ePrius
    ePrius Member
    162
    76
    Thanks for the info. It looks amazing!
  7. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Hey thanks rockerdan! Some excellent mods there; I just ordered some LEDs and I'm looking over your other ideas. Nice lookin' ride and thanks for sharing!
    rockerradio
  8. Yamada6
    Yamada6 New Member
    SF Bay Area
    Will you send me the link/info on the front plate relocator?
  9. rockerdan
    427
    83
    Wheatfield NY
    I would love to hear from anyone who has added LED bulbs to their signals. I am not sure what type to use. they need to be amber/yellow.
    As for backup lights I think they are same as plate/parking T10 wedge style/clear. I want to do these too.
    Dan
  10. rockerdan
    427
    83
    Wheatfield NY
    The link for bumper plugs is above the pic.....I simply removed my stock plate bracket, trimmed it down and mounted it onto the lower front grill area under bumper.
    Dan
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Thank you for taking the time to put together such a well thought out thread and including links. Great work!
  12. rockerdan
    427
    83
    Wheatfield NY
    no problem :)
  13. joey185
    joey185 Junior Member
    24
    Oregon
    Four Touring
    More pics side by side of spacers before and after would be great. Can see the difference , but it must be more noticable in real life.
  14. rockerdan
    427
    83
    Wheatfield NY
    I took as many as I could....the one comparison pic is where you see it the most. For people like me who have worked with custom wheels on many cars over the years, it really is easy to see. I know when i show my girlfriend ect, they just dont see it.LOL
    In real life it is very plain, since the stock wheels on all prii are so sunk in, especially in the rear. If you wanted them even more flush I would go 25mm rears and 15mm fronts. I just did not want them too far outward, since they are stock and narrow they would start to look alittle odd IMO being too flush or further out. Wider wheels/tires can pull of the "poke" look much better.
    The Rears are most noticeable...being 22mm thick, If i lower it then the difference is even more noticeable.
    BEFORE (STOCK)
    AFTER(Spacers 22mm rear & 10mm front)
    joey185 likes this.
  15. rockerdan
    427
    83
    Wheatfield NY
    Few more pics....you can see the spacers good from behind.
  16. joey185
    24
    Oregon
    Four Touring
    Looks perfect
  17. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    Looks good! Good job on the spacers too! Really made a difference! How as the install of the new studs? Are they pretty straight forward? I'm planning to put 10mm spacers on my rear and would need to replace the studs as well.
  18. rockerdan
    427
    83
    Wheatfield NY
    I would not bother with 10mm on rears...they are set in so far 22mm isnt really even enough to get flush. If i did it again id likely use 25 rear and 15 fronts. The bonus with everything over 15 is they have the studs built in, so the install is basically same as changing a tire. very fast.
    The stud replacing you can see i posted pics of how to....alot more work for sure but easy.
    Dan
  19. joey185
    24
    Oregon
    Four Touring
    The front look pretty darn flush?
  20. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    I'm already running 5mm spacers in the rear but I want to go 10mm that's why I'm asking. Im running 18x8 +35 right now and wanting to go +30.
