Rod Nock, but no broken rod or collar
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pyromanci, Jun 20, 2025 at 2:36 PM.
  1. Pyromanci
    Pyromanci New Member
    Yesterday
    MI, USA
    So I have 2014 with about 168K miles on it. About 2mnths ago i was leaving work and suddenly the car was shaking. It sound and acted like i had a flat. So I looped back into the parking lot entrance got out checked the car. All seemed fine. I got back in started it back up and nothing seemed out of the ordinary. The noise and vibration that was just there was gone. There was no engine code thrown or check engine light. During the drive home it seemed and acted fine. Did so the rest of the evening.
    Next morning when I went to leave however the engine started making a lot of noise and rocking. Now the check engine light comes on. When I checked it was a misfire in Cyclinder1. I knew i was due for sparkplugs. so just ordered them and coils and let it sit there tell I could change them. The problem continued after changing plugs and coils. So I took it to a shop as it was not out side my "I can do that myself comfort zone". So took it to a couple shops and they all said it was thrown rod or collar on Cylinder 3.
    The quotes i got to fix it were 2x the value of the car. So looked into how hard it would be to do a JDM swap myself and saw it wasn't that hard. Everything is mostly bolt on with a couple parts to swap. So I went shopping and found what i thought was a decent one. After doing the swap, brought over fuel rail, egr, and intake. I went to fire it up for the first time. It started rocking right away. I did the normal triple check over every bolt, wire, and hose. It was all correct
    I tore down the original block. I wanted to see the damage and what was actually broken. Possible even repair it/ The only damage I saw was 2 scars on Cylinder 3 pistons bearings, but the scars can't be felt when you rub your finger on them. You can only see the scratches. Everything else about it seemed to be fine. None of the pistons, crackshaft, or cam shafts seemed to have anything actually broken. There is no sign of anything that would explain the level of rocking i was seeing. I did discover the initial misfire was a failing head gasket. It had only just started fail by the looks. There was no milk shake any where yet, but I did see it starting to form.
    The fact i have seen nothing actually broken combined with the other engine doing the same, I don't know if perhaps it's something else that could be causing the rocking. This time it seems like it is Cylinder 4 not 3, but i could be wrong.
    Any one have some things to look for or check? I can drop pictures as needed.
    51,036
    a lot of variables and thoughts:
    are the plugs and coils oem from a dealer?
    how did all the shops diagnose the thrown rod?
    could the replacement engine be bad?
    could a small head gasket leak cause that level of shaking?
    these engines can sometimes knock/shake on cold start up due to moisture and/or unburned hydrocarbons in the manifold. that is their nature
    have the egr systems been cleaned on either engine?
  3. BiomedO1
    BiomedO1 Senior Member
    2,727
    1,456
    SacTown, Ca
    I must be getting really old; since you can see all the way down to the thousandth of inch tolerances:(:confused:.... Did you do any measurements, or know if something is slightly bent or warped?? Not all head gasket leaks result in milkshake oil; as you found on your car.
    IMHO; These cars has much tighter tolerances, burn leaner, and made out of aluminum and plastics. This is NOT your grandpa's model-T with an iron engine producing < 50 HP; so the eye-ball method isn't going to cut it.
    I would drop a rebuilt into it, if you want to keep it. Gambling with another used gen3 bomb is just asking for trouble.
  4. Mendel Leisk
    40,491
    P0301?
    Ever cleaned EGR?
    Very likely head gasket failure, leaking coolant into cylinder one. Boroscope inspection of the combustion chambers is a good first step: look for exceptional clean cylinder top (cylinder one), pooling coolant, coolant tears running down from head gasket seam.
    It tends to fail on the common wall between cylinders one and two, on the exhaust side.
