Rodent-warmth-magnet difference after driving?--NiMH vs. Li-Ion
Discussion in 'Gen 4 Prius Main Forum' started by unclejs, Mar 6, 2025.
  1. unclejs
    unclejs Junior Member
    Massachusetts
    When parked after driving--typically after 12 highway miles @60 mph, then 3 miles @40mph--wondering if reliable information or data might be available indicating significant difference in Gen 4 2017-2022 retained vehicle heat/warmth attractive to rodents for nesting in cold weather...between NiMH vs. Li-Ion battery models?
    Reason for this odd Q: my 2018 Prime w 76k miles just declared total loss by insurer after rodent urine entered Li-Ion battery, despite numerous rodent mitigation measures (e.g. no charging at night, no food in car, trapping up to 20 field mice/week, wire mesh above cabin filter, balsam fir oil deterrent, etc) after rodent-damaged wiring harness needed replacement in 2020. Live in semi-rural MA town nearby wooded areas providing wildlife including rodent habitat.
    However 2010 Prius in same location for 8 yrs had some rodent nesting signs, but not any damage that required repair.
    Insurance agent says another rodent damage claim would probably cause non-renewal or cancellation, so want to replace Prime w less valuable used non-plug-in 2017–2022 Prius...most models Li-Ion battery, but NiMH available on 2017-2018 trims One and Two, and AWD's since 2019.
    Have read that Li-Ion battery generally generates more heat during charge and discharge…on other hand NIMH approx twice the size and heavier, and Toyota reportedly has invested R&D in lithium cooling technology so choice not clear to me.
    Am willing to accept lower mpg and performance with NIMH if vehicle parked after driving retains less heat and/or for shorter period of time vs. Li-Ion, but so far haven't found any reliable information or data indicating significantly less NIMH heat attractive to rodents in cold weather.
    Also--was surprised and disappointed Prime lithium battery containment was capable of being penetrated by rodent urine…vaguely recall thread seeming to indicate NIMH containment might be more sealed/protected than lithium because greater lithium heat needs breathability to dissipate heat more easily, but not clear. If NIMH containment/sealing is more protective than Li-ion, that would seal the deal for me in favor NiMH.
    Would welcome and very much appreciate any reliable information or data related to post-driving retained heat differences between the two batteries.
    Thanks much! James
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Lithium is more sensitive to maintaining a constant temperature, does not like cold temperatures.
    NiMH is more unpretentious, so it tolerates cold temperatures easier, but in a very hot climate the battery heats up and fails.
    It is not clear how mice could crawl into a high-voltage battery.
    The technological holes are small.
    Is there a mesh on the ventilation grill?
    I think the issue is not the heat of the batteries, but that the grates do not cover the holes through which the mice enter.
    BiomedO1 likes this.
  3. Mendel Leisk
    42,314
    There’s a couple more egress points, assuming it’s similar to gen 3, at the sidewall back corners below hatch floor, exit vents for the hybrid battery, with flexible material flap/louvres, sim to a dryer vent.
    Likely simplest, and what I did, was remove back bumper and fashion little rodent mesh boxes to cover from the outside. the vents have plastic frames you can screw into, avoids creating rust points.
    MAX2 likes this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,558
    2,394
    Left Coast
    IMHO; It really doesn't matter. An animal is just looking for someplace warm and dry to bed-down in. They don't really care if it NIMH or Li-ion cells they're sleeping on......
    #4 BiomedO1, Mar 7, 2025
    Deleted member 219929 likes this.
  5. bisco
    52,814
    It’s hit or miss, not one car vs another.
    My 2012 was parked in the same garage for 7 or 8 years no problem, and then one day the mice took over.
    No problems since
