Rodents chewed my speed sensor wire...how hard is to replace?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by J wil, Dec 21, 2018.
  1. J wil
    J wil Junior Member
    30
    16
    Punta gorda
    Hello everyone… It appears that rodents have chewed my speed sensor wire and I need to replace it it’s on the front left wheel. My local Toyota dealer has quoted me $630 out the door. I am a level three out of five mechanic… So I’m pretty good at stuff how hard is it to replace this wire myself?
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    The harness is 90-$120. I have no idea what has to be taken apart to access connectors, but $650 seems high. Can the sensor wires be repaired in situ?
  3. Mendel Leisk
    38,735
    Have you had a good look, determined how much and where it it is chewed up? If it's an inch or two damage, accessible, I would just cut out the damaged area, splice in new wire of the same gauge, wrap it securely. Stagger your splices to avoid possible shorts.
    Jury's out regarding crimping-vs-soldered, which is more secure, but just for neatness I'd be inclined to solder, intermeshing the strands and ensuring the wires are well heated, flow the solder on.
    Raytheeagle and Air_Boss like this.
  4. J wil
    J wil Junior Member
    30
    16
    Punta gorda
    The toyota service manager stated that i could do it myself...but they need to do the calibration to the computer. Does this sound correct? Or did i just buy blinker fluid?
  5. J wil
    J wil Junior Member
    30
    16
    Punta gorda
    They are doing the job tomorrow. Ive got time. If i do the “wire splice” option myself. How would i clear all of the dash lights? How would i get the pcs to realize it was fixed and now communicating? Reeboot?
    Btw. Thanks to you all for your help on this! Happy holindaze!
    #5 J wil, Dec 21, 2018
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Who’s that guy in the avatar:whistle:?
    Hope you saw him before it was too late:eek:.
    A canucks fan if nothing else (y).
    Air_Boss, m.wynn and Mendel Leisk like this.
  7. Mendel Leisk
    38,735
    Someone asked me to clean the lens on their back up camera, and you see what happens...
    m.wynn and Raytheeagle like this.
  8. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Looks clean:).
    Wonder how bad it was before, or maybe we don’t want too:oops:.
    Job well done(y).
    Mendel Leisk and m.wynn like this.
