Rolling Stone Magazine does not Heart Ethanol
Discussion in 'Environmental Discussion' started by Tempus, Jul 31, 2007.
  1. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Ethanol Scam: Ethanol Hurts the Environment And Is One of America's Biggest Political Boondoggles
    As the king of ethanol hype, Sen. Chuck Grassley of Iowa, put it recently, "Everything about ethanol is good, good, good."
    This is not just hype -- it's dangerous, delusional bullshit. Ethanol doesn't burn cleaner than gasoline, nor is it cheaper. Our current ethanol production represents only 3.5 percent of our gasoline consumption -- yet it consumes twenty percent of the entire U.S. corn crop, causing the price of corn to double in the last two years and raising the threat of hunger in the Third World. And the increasing acreage devoted to corn for ethanol means less land for other staple crops, giving farmers in South America an incentive to carve fields out of tropical forests that help to cool the planet and stave off global warming.
  2. Washington1788
    Washington1788 One of the "Deniers"
    197
    Alexandria, VA
    <div class='quotetop'>QUOTE(Tempus @ Jul 31 2007, 01:23 PM) [snapback]488195[/snapback]</div>
    I think the one thing that is certain is this is a big boon for the corn growers. While I'm glad we can help our farmers out (at least a specific segment) it causes a number of problems across the board which may not make Ethanol a viable long-term option.
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(Washington1788 @ Jul 31 2007, 02:29 PM) [snapback]488237[/snapback]</div>
    That may help the corn growers, but I'll bet it's causing major headaches for other farmers. Those that depend on corn for the feed for their animals are going to feel the pinch. Either the price of their meat is going to go through the roof because of the escalating feed costs, or they're going to go bankrupt.
  4. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    farmers who grow corn just to feed their livestock are really getting hit. my family back home has a dairy farm, and corn prices are really hurting their bottom line. they haven't seen an increase in milk checks to reflect the increased cost of corn seed. they don't have a lot of choice, they need the corn. being a small family farm is hard enough without this.
  5. Godiva
    10,339
    With the price of corn going up, is there a viable alternative feed? Mixture of hay and grain or something? I know cows are fed corn because it's cheap, but it's also not the healthiest diet for them. If corn becomes as expensive as the alternatives, is it possible to substitute an alternative for the corn?
  6. Trollbait
    12,351
    There are alternatives for feed. Some of the ethanol waste is even used as feed. But once one goes up in price, it is just a matter of time until the rest do. Then there is the issue of getting the same levels of production. Pasture fed cows give the best tasting milk, but at cost of volume. It's been years since I took the class, so I may be way off, but I want say the pasture fed cow might make nearly half the volume.
  7. galaxee
    9,810
    468
    MD
    when everything's all frozen in the winter they have to feed whatever they have stored up. the hay mow won't hold enough hay to feed all the animals all winter, and round bales are fed outdoors which only takes care of part the problem. so they fill the silo with corn silage and that's usually almost enough to get them through. by the end of winter they're buying feed which is much more expensive than growing and storing it yourself.
  8. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    The solution is to move away from corn as a feed stock. Unfortunately, that means getting other feed stocks down in cost. Of course, as corn prices spike, the profit margins on ethanol will plummet and that might make ethanol alternatives more favourable.
  9. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(tripp @ Jul 31 2007, 07:37 PM) [snapback]488374[/snapback]</div>
    Unless they continue to use our tax dollars to subsidize ethanol for fuel, which seems to be the plan.
  10. scargi01
    scargi01 Active Member
    784
    57
    Missouri
    <div class='quotetop'>QUOTE(galaxee @ Jul 31 2007, 05:01 PM) [snapback]488326[/snapback]</div>
    And while the cost of corn goes up, it is being matched by the cost of hay. The supplies to cut & bale hay have gone up 30% in the last year alone due to the rise in oil prices. I buy round bales and am paying $40 per bale this year. Last year it was $27.50.
  11. Darwood
    Darwood Senior Member
    5,259
    268
    Even without ethanol, costs of everything mentioned above will continue to go up as the cost of oil goes up.
    Recently the price of milk DID shoot up. These things are normal and should happen. They will force us all to eat and live more efficiently. Instead of sending our surplus corn overseas, we'll convert it to fuel. The ramping up of this process will match the ramping down of the oil imports we are able to get INTO the country.
    Besides, it's not the corn ethanol that is important here. Setting up the biofuel infrastructure is what is important. Doing it on the backs of the corn subsidies that have been there for YEARS, is just a way to make the investment in this infrastructure profitable instead of a feel good money losing excercise. We subsidize oil just as much, if not more than ethanol.
    I'm not saying ethanol is the future, small EV's and less transportation in general is the future, but we WILL need biofuel in some form or another from multiple feedstocks and it will be nice to have the plants up and running for when we do.
  12. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(Tempus @ Jul 31 2007, 06:07 PM) [snapback]488385[/snapback]</div>
    The subsidies are included. The price of corn has almost doubled since 2005. That really cut into the profitability of ethanol.
  13. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(tripp @ Aug 2 2007, 10:52 PM) [snapback]489753[/snapback]</div>
    Direct subsidies aren't the only ones we need to consider.
    If you mandate Ethanol as a Fuel Oxygenator, then the added cost of Ethanol is passed through to the consumer. That's a subsidy, but one that transfers the money from us rather than through the government. The Ethanol Producers can charge whatever they need to be profitable because the consumer is hostage.
    Example
    The ethanol subsidy is worse than you can imagine
    The greens, hawks, and farmers helped convince the Senate to add an ethanol provision to the energy bill—now awaiting action by a House-Senate conference committee—that would require refiners to more than double their use of ethanol to 8 billion gallons per year by 2012.
    The two scientists calculated all the fuel inputs for ethanol production—from the diesel fuel for the tractor planting the corn, to the fertilizer put in the field, to the energy needed at the processing plant—and found that ethanol is a net energy-loser. According to their calculations, ethanol contains about 76,000 BTUs per gallon, but producing that ethanol from corn takes about 98,000 BTUs. For comparison, a gallon of gasoline contains about 116,000 BTUs per gallon. But making that gallon of gas—from drilling the well, to transportation, through refining—requires around 22,000 BTUs.
    In addition to their findings on corn, they determined that making ethanol from switch grass requires 50 percent more fossil energy than the ethanol yields, wood biomass 57 percent more, and sunflowers 118 percent more. The best yield comes from soybeans, but they, too, are a net loser, requiring 27 percent more fossil energy than the biodiesel fuel produced. In other words, more ethanol production will increase America's total energy consumption, not decrease it. (Pimentel has not taken money from the oil or refining industries. Patzek runs the UC Oil Consortium, which does research on oil and is funded by oil companies. His ethanol research is not funded by the oil or refining industries*.)
    Read all of it.
    More
    Last week, the Senate passed an energy bill mandating the production of 36 billion gallons of ethanol per year by 2022—a sevenfold increase over current levels. Senators congratulated themselves for their environmental foresight. The president, a biofuels advocate, has enthusiastically endorsed the ethanol surge. But it's almost certainly a fantasy, since no one in Washington seems to have thought for five minutes about where or how that much ethanol could be produced.
    The Senate's ethanol mandate will increase the consumption of corn, the single most subsidized crop in America. In 2005 alone, according to the Environmental Working Group, corn subsidies totaled $9.4 billion. By increasing ethanol production—and thus corn production and consumption—the mandate will likely cost taxpayers extra billions both in the form of higher subsidy payments and higher food costs. But set aside the budget concerns for a practical one. How much ethanol can be produced from corn?
    According to the U.S. Department of Agriculture, distillers can produce about 2.7 gallons of ethanol per bushel of corn. In 2006, U.S. farmers produced about 10.5 billion bushels of the grain. So, even if Congress mandated that all of America's corn be turned into ethanol, it would yield only about 28.3 billion gallons, far less than the mandated volume. And, clearly, most of America's corn is still going to be used for animal feed, family barbecues, and high-fructose corn syrup.
  14. Darwood
    5,259
    268
    But oil hit an all time high also, which makes ethanol look real good too.
    Oil, ethanol, corn/milk/etc are all commodities that are "rubberbanded" togethor. One goes up, the others do to. This is not going to change.
    Calling ethanol an energy loser is short sighted and a bit of a misnomer.
    Those calculation are based on the past (and current) farming methods which are very inefficient. Farmers have never had to worry much about fuel usage, as it's always been pretty cheap. They will be forced to improve, as will the whole biofuel process. Also, the energy inputs can be (and should be) more green, as opposed to fossil.
    On the other side of the equation, every year, worldwide oil production is becoming more and more energy intensive. What used to be 1 barrel input to 30 barrels output, is more like 1:5 now and getting worse. IE: tar sands, which are worse than 1:5 and getting heavily funded due to a lack of other options. At least with ethanol we'll be able to keep the money in the US instead of funding OPEC, and we need to hedge our bets anyways with investment in ALL energy fronts. We aren't building biofuel infrastructure for profit today, we are doing so to provide energy security for tomorrow. Or does tomorrow not matter?
  15. richard schumacher
    7,664
    1,043
    United States
    Darwood, Darwood, Darwood... farmers have always cared about fuel prices. The means for adding ethanol to fuel already exist and will not be helped by continuing subsidies for *corn* ethanol. Corn ethanol fans should arrange for periodic debitting of their checking accounts direct to Cargill, ADM, and the re-election campaigns of certain plains states Senators, and leave the rest of us out of it.
    US farm policy is both fiscally irresponsible and immoral: welfare for rich landowners which simultaneously strangles the free-market efforts of farmers in developing nations to establish themselves.
  16. Darwood
    5,259
    268
    I completely agree that *corn* is not the best biofuel.
    But to compete with oil, the biofuel industry needs artificial price pillars. Oil companies receives far more economic support that ethanol producers do in the form of military protection of assets, land rights for resource extraction, as well as direct subsidies and tax breaks. Ethanol producers need to get their infratructure expanded BEFORE we start to hit the inevitable downlope of oil supply, and that means investing in something that doesn't really look like a money winner currently.
    I would love for the subsidies of corn to be switched to better projects like agricultural waste product conversion to biofuel, but lets face it, the current administration is NOT going to allow competitors of the oil companies to get any advantage. So they are building plants on the back of subsidized corn. But the plant processes can be changes at any time to process many different feedstocks and produce not just ethanol, but other types of biofuels, plastics, or other end use products.
