Rolls Royce EV Test Drive
Discussion in 'EV (Electric Vehicle) Discussion' started by GrumpyCabbie, Apr 1, 2011.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    First test drive of the Rolls Royce EV prototype.
    BBC News - Driving the electric Rolls-Royce
    I like the idea of induction charging - why hasn't it been taken up by other manufacturers? I understand even the GM EV1 had it. I also note from the article that the Rolls Royce EV has the largest battery pack in any EV. Does this mean that we're going from Gas Guzzlers to Electric Eaters or something similar?
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    How is "largest battery pack" measured? The BBC did not report any specs. Tesla's Model S pack appears to be most of the length & width of the car. It certainly is too large to fit under the bonnet.
  3. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    The EV1 had an inductive paddle, which doubled as both a safety and convenience thing. I don't particularly want to waste 8% of the power going into the car (the charger itself will already be wasting that much or more), however, i can see a future for inductive charging at shopping centres, cinemas etc when you want to opportunity charge.
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Now that's an idea. I wonder if there's an easy way to have the normal 'plug in' chargers with the car but an additional inductive charging system for when you park at the supermarket etc?
    That way you get the benefit of a full, efficient charge at home but the convenience of the inductive charging when out and about? Who wants to mess around with plugs when you've just filled up your car with shopping/groceries? In a supermarket you'd also have the possibility of someone unplugging your charger (inadvertantly or not).
    Is an additional inductive charger an expensive additional cost?
  5. Flaninacupboard
    1,297
    213
    Midlands - UK
    One which can transfer the amount of energy needed to chagre a car, yes. The Roller actually has both options.
  6. Tideland Prius
    16,128
    That would be a good idea, although it may mean one has to park head first if the charger is placed inside the parking space, close to the wall.
  7. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    make the roadways one big inductive charger.
    range problem solved
    despite being absurd, it would probably cost a fraction of what we've spent on our oil wars.
  8. UsedToLoveCars
    448
    102
