Roof molding coming off during car wash
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by metanewbie, Apr 10, 2023.
  1. metanewbie
    metanewbie New Member
    I have a 2013 Prius C. The roof molding rubber strip on one side of my car (top of the roof) starts coming off during a car wash. I was wondering what I can put under there to keep it sticking (like a glue or silicon) that won’t harm the paint. Can you suggest any particular brands/models of glue or adhesive?
    Thank you!
    G Dog likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    There's a pair of little metal tabs on both ends that get bent out of position, so you need to adjust them so they don't slip and cause lifting in the middle. As for glue, I've used a tiny bit of 5 minute epoxy on the tabs but have never tried to glue the strip down in the middle.
  3. metanewbie
    In this case, it doesn’t lift in the middle. I don’t see any tabs. This molding is on the roof and it seems to slide on. The rear part of the molding comes off and flops around.
  4. PriusCamper
    11,104
    4,518
    Yeah, maybe PriusC is different than regular Prius... Main thing is get 'em real clean and ensure the fastener is working correctly and then use a tiny bit of epoxy. Not as big of a deal in the rear, it's when they come loose up front that you lose them on the freeway.
  5. metanewbie
    Great advice. Thank you.
  6. PriusII&C
    PriusII&C Active Member
    370
    129
    San Jose, California
    What functions does it play anyway?
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,172
    2,213
    Taylors, SC
    This is 3M Plastic and Emblem Adhesive, 08061 made especially for the purpose..
  8. PriusCamper
    11,104
    4,518
    It's a decorative strip... Mostly needed to hide the welds that connects the various roof parts together... It helps to reduce cost of production.
    Tesla has become famous for the world's largest metal presses that can take a giant slab of sheet metal and create nearly the entire car body in one massive thump of tens of thousands of pounds of pressure. This requires massive upfront cost, but in the long run is way cheaper than having a bunch of robots weld together a car body from separate pieces.
