Roof rack and mileage decreasing
Discussion in 'Prime Main Forum (2017-2022)' started by Bluebells2, May 24, 2018.
  1. Bluebells2
    Bluebells2 Junior Member
    46
    Silver Spring, MD
    How much mileage do you lose when using a roof rack. How much mileage do you lose when using a roof rack How about if use your roof rack with a bike or kayak . Since it’s summer I tend to leave the rack on the car all summer and take it off in the late fall and I wondered what mileage I would be losing . Thanks
  2. Trollbait
    12,351
    Did you keep track of your fuel economy of the last car with a roof rack? We could calculate an estimate from that.
  3. Bluebells2
    46
    Silver Spring, MD
    Sadly no, but it dropped it by about 20 percent
  4. fuzzy1
    10,335
    Don't expect any less on a Prius. In fact, expect more loss, because while your new car has improved efficiency and aerodynamics compared to its predecessors, racks and the stuff carried on them will be unchanged, thus will be responsible for a greater fraction of your total fuel consumption.
    Hitch racks on a Prius are also lossy, as most of the bike structure is not in wind shadow, but out in the full wind blast. With bikes loaded, mine costs at least 15%. And I don't drive as fast as average traffic in your area. When cargo permits (which isn't often), I put our bikes inside instead.
    Bluebells2 likes this.
  5. Mendel Leisk
    40,583
    Depends a lot on speeds involved too, I would think.
  6. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    This was from an article I just read:
    Consumer Reports tested a 2013 Honda Accord at a steady 65 mph. With nothing on the roof, the car got 43 mpg. An empty bike rack cut that to 38. The fuel economy dropped to 27 mpg when two bikes were attached to the rack.
