Roof Rack
Discussion in 'Prius c Accessories and Modifications' started by Chirogeoff, Jan 22, 2013.
  1. Chirogeoff
    Chirogeoff New Member
    Acworth, Ga
    I would like to add the thuli roof rack, but I don't like that it is a permanent solution. How much does it affect the MPGs on the highway. If its only 5 or 6 mpgs that wouldn't be too bad, as long as it isnt affecting the city mileage when it is empty.
  2. Ryan Case
    Ryan Case Junior Member
    38
    Normal, IL
    From personal experience, roof racks without a bike on cause a substantial impact on mpg. I usually assume 10% on the highway for a regular vehicle, I would suspect given the focus on aerodynamics in conjunction with the low power output on the PC - you would be looking at closer to 15% without anything on it. With a pair of tri bikes I would say 5mpg on my old 3 series wagon's. I wouldn't be surprised to hear 15mpg+ loss.
  3. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Using a fairing helps eliminate the mpg loss.
    Requiem likes this.
