Roof Top Tent... Am I crazy?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jjdd, Mar 2, 2019.
  1. jjdd
    jjdd New Member
    CA
    Looking to purchase a roof top tent for my 4x4. However, might mount it in the Prius too. Looking at one that weight 95lbs and another that weighs 115lbs. Any insights about mounting it on the Prius?
    SFO likes this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    It’s too heavy. Just use it with your 4x4 and give your poor Prius a brake.
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Anything is possible, but I agree with Skibob on this.
    Skibob likes this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  5. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    The inside is perfect for sleeping, but if it's full....
    Heads toward the front, on your side curled, don't break the antenna, use a foam roller for 1/2 hour each morning.
  6. HaiImBrian
    HaiImBrian Junior Member
    45
    Los Angeles
    I guess we are both crazy then because I plan on using a roof top tent on top of my Prius. I currently have it on my 4 runner but the fuel consumption is killing me. Most of my camping trips are just to drivable campsites and I just like the convenience of the tent. Plus it's really nice waking up at a higher elevation.
    I've had experience with putting a heavy cargo box on my Prius fully loaded with about 120+ of dynamic load. Since the roof top tent only weights 95 lbs, I don't think it would be a problem while driving. Also for load, most cars are designed to have a roof not collapse under in case of roll over. The stress point loads is on the frame of the Prius and not directly on the roof.
    I've done my research and although it's not recommended by manufacturers, many have used the clamp style roof racks for their roof top tent. I specifically have and like the thule brand cause its pretty bulky compared to others.
    Check out this video of this company's roof top tent. The fiberglass tents weight close to 200 lbs and they advertises that it works perfectly fine.
    Also check out this guys video comparing MPG impacts
    Please let me know if you have any updates on this cause I would love to see what others are doing.
    mmmodem and Bunce like this.
  7. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    I wouldn't know why you shouldn't do the roof-top tent on the Prius. Weight shouldn't be a problem, assuming neither of you are sleeping up there while driving! Speed will make even more of a difference with your gas mileage with the roof rack. A number of years ago our family of four did a cross-country trip with our '04 with all the camping gear, including some on the roof (not a roof top tent) and we averaged 50 mpg, but we consciously decided to only drive 60 mph. Your experience may vary.
  8. Skibob
    2,912
    1,496
    Northern California
    What’s the advantage of using a roof top tent vs a regular tent you set up in the ground?
  9. Leadfoot J. McCoalroller
    7,173
    6,719
    Pennsylvania
    2018 Prius c
    Depends on what sort of critters you're sharing the ground with.
    Some rooftop rigs are really fast and easy to set up, but that isn't universal. Most of them come with a large MPG & wind noise penalty on the highway, no matter what they're on top of. Not all stay dry when you drive through rain on your way to the campsite.
  10. HaiImBrian
    45
    Los Angeles
    Overall.. the roof top tent is a definate luxury item that is not needed when camping. But.. most roof top tents have memory foam mattresses, can be set up with one person in a few minutes with minimal effort, and it's just amazing being at a higher elevation and seeing nature.
    It makes things easy so you don't have to worry about finding a clean flat ground and is always ready to go when you need it.
  11. jjdd
    jjdd New Member
    CA
    So... I went ahead and mounted the roof top tent and wanted to give a follow up. I own a 2007 prius. I mounted Thule Aeroblade bars (ARB53) on the roof. Rated at 165lbs. I also found some evidence that prius roof will take 165lbs (European manual). Important to note that they are ratings for dynamic and static weights. Dynamic meaning while you are moving and static just as it seems. Dynamic rating is the important one and is 165lbs in this case.
    I mounted Tepui's Ayer 2 on the car. Looks a little funny but worked nonetheless. Average gas mile for me is normally 42mpg. I averaged 38mpg on a 1000 mile road trip through Zion and down through the Grand Canyon. I was mindful of my speed at first but eventually went around 70mph with no problems at all. Tent weighed 115lbs fully geared up with sleeping arrangements packed inside. Awesome setup once you open it. No problems.
    Let me know if you have any questions!
    Update: I have since upgraded to a slightly larger model (9lbs heavier) that has much more room. Will report back after first trip on the prius. Have only taken it mounted on my FJ Cruiser.
    Zak411, Priusjames, m3pare and 3 others like this.
  12. HaiImBrian
    45
    Los Angeles
    OMG YES! exactly what I was looking for. I'm glad others have reported great success using the clamp on system. I am also using the same Thule set up as you but on my 3rd gen instead. It's a great roof rack and plenty strong.
    Seriously at 38mpg, this is a no brainer for "Glamping"
    Thank you for sharing and I'll share my experiences as well.
  13. HerbMPG
    HerbMPG Junior Member
    25
    Decatur GA
    Doesn't this rooftop tent kill your prius gas mileage? Perhaps not as much as your SUV?
  14. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    Herb, he is probably getting "slightly" better mileage than the 6.8 MPG I'm getting with my Prius camping setup. Biggy and Daddy Car.jpg :)
    Priusjames and Skibob like this.
  15. Skibob
    2,912
    1,496
    Northern California
    Seems like he used 2.5 gallons more gas on the trip if his mileage stats are correct for the 1000 miles. I wouldn’t call that a deal breaker. Unfortunately my fat behind would bend the roof if I did that. :ROFLMAO:
  16. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    Bob, you'd be surprised how much structure those Thule or Yakima rails add. That setup looks nice though, about half the weight looks too be supported by the ladder.
    SM-N950U1 ?
  17. HaiImBrian
    45
    Los Angeles
    Yup... definitely not as much as an SUV. He stated an mpg hit and averaging 38 mpg which is way better than what most SUV's are getting.
    Yes the ladder does help hold some of the weight but I wouldn't account it for half the load. It really depends on where your body to resting in the tent. I would say its more of a 25/75 weight distribution.
  18. HaiImBrian
    45
    Los Angeles
    Update: So I just test fitted my Yakima Skyrise on the prius getting ready for the weekend trip. I am gonna drive it around to commute to work for a while to see if there are any issues before the long drive. The load bars seem extra sturdy and had no issues inside. The load bars are extra sturdy and doesn't look like it will budge. Thule rated the brackets to hold up to 110 lbs but the new EVO brackets are rated up to 165 lbs. I think I should be fairly safe with this setup.
    Check it out!
    Skibob likes this.
  19. barbland
    barbland Junior Member
    los angeles
    Hi!
    Do you know if your Thule Aeroblade bars (ARB53) fits a 2012 Prius as well? I was looking at those tents too, are they quick to open and close? Do you still recommend it?
    Barbara
  20. moshbit
    moshbit Junior Member
    Washington
    Apologies for the necropost, and I know neither of these users have been online in a year, but I'm hoping maybe they'll see this and give us an update on how these turned out since I'm planning on doing something similar.
    @hailmbrian @jjdd
    Bunce likes this.
