Roof trim help
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by edteach, Jan 26, 2020.
  1. edteach
    edteach Junior Member
    37
    sarasota florida
    2014 Prius c
    The Trim on my roof the black insert trim has come loose and is flopping around. I glued it in with trim glue and its not holding well. I guess I have to buy new. I was wondering if there is a left and a right and is there any after market place to get them. Thanks for any help
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    Maybe try some very strong 3M double sided tape rated for outdoors.
  3. PriusCamper
    PriusCamper Senior Member
    11,105
    4,520
    Pacific Northwest, USA
    I'm not sure if Prius C is different but if it's the same as the long inch wide black strips on roof of Gen2, there's some clips that hold it in place and by bending those clips a little, that should hold it all down.
  4. edteach
    37
    sarasota florida
    2014 Prius c
    The clips hold the ends in but the center section is friction and they shrink over time and flop. I tried glue but it does not seem to hold. I could use 3m body tape but it will make it a bit higher.
  5. PriusCamper
    11,105
    4,520
    Maybe it would be easier to just replace the strips? There's a bunch of companies that provide aftermarket auto trim in every possible dimension and you could possibly order something that's not only inexpensive, but doesn't come loose due to shrinkage over time.
    And if you do find something that works better, I'm sure there's lots of Prius C owners on here that will want to know about it.
  6. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    After replacing both sides for the same problem, the strips once again started popping out while going thru car washes about a year later. But I have seemed to found a fix.
    I found a can of this on the shelf at my parents house.
    Yes, it's brush on gasket seal. Extremely tacky, but easy to work with. I removed a strip, placed it on the garage floor upside down and brushed in this gasket seal. Then, with the help of my brother holding one end, we re-installed the strip. So far it's held in place for a little over a year now.
    This "high tack" gasket sealant can be found at any auto parts store and even Wal-Mart for under $10.
    skayaks likes this.
  7. topshot
    topshot Member
    142
    56
    Midwest
    2015 Prius c
    I just removed mine since they serve no purpose.
    PriusCamper and dubit like this.
