Rookie mistake while bolting water pump back up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ohsheet, Oct 16, 2024.
  1. Ohsheet
    Ohsheet New Member
    So I pulled a rookie mistake and I'm hoping I'm not screwed big time..I changed the head gasket on the vehicle..with that being said you know there's all sorts of bolts shapes and sizes everywhere..so I get everything back on and back together after changing head gasket and I put oil and check for any type of leaks, none, so I proceed to pouring coolant..this time I hear drip......drip....drip......drip..so I'm able to follow it and see it's coming from behind the water pump..unfortunately it turns out I pulled the rookie maneuver and used a bolt that was too long when bolting the water pump back up..it went through and chipped a piece of the block off, enough to have it leaking through it a bit..so I'm hoping to be lead in the right direction, some advice, hoping to hear some great like "it's fixable", hoping I'm not completely screwed and left having to dish out major bucks for new parts..a new block?..definitely hope that's not the case I don't know..but thank you all in advance..thank you, you and you
  2. oskr24
    oskr24 New Member
    Australia
    Can't help sorry but curious as to what you did next. Where you able to fix it?
  3. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    Not a mechanic by trade but... I'd find the chip, empty coolant, remove the bolt, clean chipped area with brake cleaner, wait for it to dry then put the chip back with the strongest epoxy... what does everyone think?
    SM-A536V ?
  4. Frontporch
    Frontporch Active Member
    536
    121
    Nj
    Trying to imagine what happened here, usually the bolt would go into a threaded hole in the block. Did the block crack before the bolt broke? One way to hopefully avoid something similar would be to always use a torque wrench... buy a 1/4 drive for the hard to reach spaces.
    I would also look into epoxy. Not sure it works great in an area where it is paper thin between two pieces. I have seen where grooves were cut in the parts to let more epoxy grip the two parts and even overlapped the sides. Seems like a worthwhile attempt.
  5. Mendel Leisk
    41,906
    Gen 3 water pump is held on by 5 bolts. Problem is: there's two different lengths of bolts, which is trouble waiting to happen. This is best avoided, and I have seen other instances where they kept a whole group of bolts the same, likely just to avoid mix-up. Too bad they didn't consider this here.
    I'm always grateful for reports like this, and 'try" to make a mental note, to not fall into the same trap. One thing you can do: get a mechanic's marker pen, mark both the longer bolt heads and the adjacent shoulder of the pump, as a reminder.
    Another good strategy is to NOT use something like a power ratchet to reinstall these bolts, just do it by the hand. If you've got an overlong bolt you'll likely figure it out before something breaks.
    #5 Mendel Leisk, Oct 28, 2024
    Frontporch, StarCaller and Brian1954 like this.
  6. Ohsheet
    Ohsheet New Member
    I did just that..and it worked like a charm I appreciate your advice/input
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,513
    6,598
    Texas Hill Country
    Op reports he JB Welded it and it held
    mjoo likes this.
  8. mhdriver
    mhdriver Member
    158
    61
    florida
    You are a treasure dude! Putting on my water pump, checking bolt locations and torque. You made it easy!
