Root cause of poor gas mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by mikeflores2000, Sep 3, 2017.
  1. mikeflores2000
    mikeflores2000 Junior Member
    52
    23
    Merced, CA
    Root cause of poor gas mileage.
  2. mikeflores2000
    52
    23
    Merced, CA
    Switching from factory spec 0-20 SAE synthetic to 5-30 SAE synthetic for high mileage may have been a mistake.
    I switched to stop the high consumption of oil ( quart per 2000 miles).
    Low oil also could be a factor. Averaging 25 MPG now.
    Taking 2010 Prius with over 140k miles in for a oil change September 6, 2017.
    Will re measure MPG and report back results to this thread.
    Danny3xd likes this.
  3. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    I wouldn't expect the change in oil viscosity to make much measurable difference in fuel mileage. What was your fuel mileage prior to the change?
    mikey_t and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    There are many other factors that can contribute to poor mpg:
    • Tire pressure (what type of pressure do you run)
    • Gas choice (top tier, bs what's around at the time you need to fill up)
    • Driving style (spirited or mindful)
    • Type of driving (mostly city, mostly highway)
    If oil consumption issues:
    • How many miles since noticed?
    • Did a light on the dash tell you about the oil use or did you find it by checking the dipstick?
    • Have you done any cleaning of the egr system (intake manifold, egr pipe, egr valve, egr cooler)?
    • Have you ever tried cleaning the oil with an engine flush?
    • Ever cleaned the MAF or changed the air filter out?
    • Have you owned the car since new?
    Keep us posted (y).
    prakashG, ALS, RMB and 1 other person like this.
  5. mikeflores2000
    52
    23
    Merced, CA
    45 MPG
  6. mikeflores2000
    52
    23
    Merced, CA
    Raytheeagle likes this.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    No, you have jumped to an invalid conclusion.
    An almost 50% drop in fuel mileage can NOT be in any way blamed on that slight change in oil viscosity.
    You have some other MAJOR problem looming.
    Tim Jones and douglasjre like this.
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I actually switched our 2010 Prius II with 162 k miles on it to 5w-30 at 120 k miles and haven't seen a drop in mpg (I average 51.3 mpg with mostly highway driving). I did this to help slow oil consumption (a quart every 4500 miles found by checking the dipstick every weekend).
    Things I have done:
    • 5w-30 full synthetic (currently running Redline and at 1700 miles on this oil change have seen no movement on the dipstick :))
    • Add BG Products MOA to the new oil to help keep it basic as long as possible (gas leaks by and gets into the oil causing it to become contaminated and degrades seals)
    • Add BG Products EPR to the oil prior to draining to remove build up every oil change (it comes out jet black every time;)). At our last Bay Area meet up, there were 3 oil changes done so I was able to compare the differences, and there was a difference ;).
    • Instead of running 10-15 mph above the posted highway speed limits, I run at 0-5 mph above the speed limit
    • I have cleaned the egr system front to back which helps ensure the air flow is correct. If the ports are plugged with deposits, in correct air to fuel mix can result
    • Run top tier fuel (it has higher detergent contents which delays the onset of deposits)
    • Cleaned the Mass Air Flow (MAF) sensor along with throttle body
    Some things to consider for your situation ;).
    Keep us posted (y).
  9. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Did you change the engine oil yourself or one of those jiffy lube places? Check to see if they put more than the specified amount into the engine, I've heard horror stories about those fast oil change places. Check to see if the dipstick is at the right level first, if you did take it to those fast oil change place, it may have more than 4.2.
    Tim Jones likes this.
  10. mikeflores2000
    52
    23
    Merced, CA
    No I didn't jump to any conclusion only suspicions. Post solicits input to diagnose drop in fuel mileage.
  11. mikeflores2000
    52
    23
    Merced, CA
    Learned my lesson. Always take to Toyota dealers and tell them to pour only 4 quarts. I top off to 4.4 quarts.
    Changed oil today 09-06-2017 and plan to monitor MPG going forward. Will report back.
  12. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Did they refill too much? If budget ain't a problem, get a fluid extractor (like below) and extract any excess through the dipstick. I moved into an apartment 2 years ago and been extracting engine oil through the dipstick nozzle so no need to lift raise the car to change engine oil. On my salvage camry, I can tap the straw right on the oil pan, straw is somewhat bendable also. If you extract too much, you can put it back as needed.
    amos likes this.
  13. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    Oil viscosity will only account for 1-2 percent change in efficiency -- maybe less in a hybrid since oil viscosity doesn't effect efficiency of the MG.
    Tim Jones and mjoo like this.
  14. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    For your vehicle to drop from 45-25 mpg is huge. Any chance someone hooked up a trailer behind your prius? Outside of joking did you have your rear brakes changed recently? Brakes dragging can be an issue or is your engine on constantly when you come to a stop sign or stoplight once it is warmed up? Could be that your vehicle is constantly charging the HV battery? Just some ideas.
  15. mikeflores2000
    52
    23
    Merced, CA
    After 6 bottles of Seafoam, MPG improved from 30 to 42.
    Brake pads are near 70% remaining so I doubt a dragging brake is occurring.
    Happy with my Prius. The 2001 VW Beetle was a lemon.
  16. padroo
    padroo Senior Member
    2,763
    2,252
    Are you manually checking your mileage by writing it down and doing the math over several tanks.
    What kind of driver are you and where do you drive?
  17. mikeflores2000
    52
    23
    Merced, CA
    Writing down fuel consumption going back at least
    24 months and 36,000 miles. Approximately 90 tanks of 87 Octane gas. Pumped premium gas
    when using 2 cans of Chevrons Techcron, 1 can of Gumout and finally 6 cans of Seafoam.
    PS: per NHSTA our 2001 VW beetle is a lemon.
    C7 Corvette in general scared me away with numerous complaints. The Porsche 911
    years 2010 - 2017 have virtually 0 complaints despite $91k price tag.
    If you are willing to get your hands dirty, maintenance on Porsche is cheaper than taking
    Prius to dealership:)
    mjoo likes this.
  18. mikeflores2000
    52
    23
    Merced, CA
    Cautious cruising at 60 MPH with occasional 90 on freeways. Between California’s Central Valley
    and San Francisco.
  19. audiodave
    audiodave Active Member
    798
    269
    US
    Changing the oil is one thing but the filter coming off without a possible oil mess is another.
  20. Anthony bush
    Anthony bush Junior Member
    Chicago
    What’s seafoam??????
