Rosen + Prius III Questions
Discussion in 'Gen 3 Prius Audio and Electronics' started by mkhan01, Jan 29, 2011.
  1. mkhan01
    mkhan01 New Member
    pville tx
    couple of questions regarding Rosen Nav HU + 2010 Prius III:
    1. Regarding JBL harness.. do you use part #: DPTYJBL1 or DPTYJBL2?
    2. Do the Prius III bluetooth/handfree steering wheel controls work w/ Rosen?
    3. Does the backup camera engage on reverse or does it have to be manually engaged?
    Thanks
    MoeK
  2. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    1. I dont know.
    2. No
    3. Yes
  3. mkhan01
    mkhan01 New Member
    pville tx
    Thanks, I completed putting in the Rosen, here is what I learned:
    1. JBL Harness: DPTYJBL1.
    2. Bluetooth controls: 2/3 work (answer (off hook), and hangup (on hook) work; multi function doesnt work b/c there is no voice activated bluetooth).
    3. Reverse does indeed work as long as reverse wire is wired and configured to auto-engage in Rosen settings.
  4. tkoo
    tkoo Junior Member
    Schaumburg, IL
    Question, I just wired my backup cam and rosen unit. Where am I supposed to wire the reverse wire to?
    I wired the power from the camera to the reverse light and know that the camera works because I can enter it manually only while in reverse, but the unit will not automatically go into the camera mode.
    Am I supposed to route the blue "Reverse" wire on the back of the rosen somewhere?
    Any help is appreciated. Thanks in advance.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    You could start by searching backup camera - many have done it - and it's probably in these forums 20+ times.
    You can get it under the dash - but I never was clear where - or at the reverse light in the back drivers light assembly (you use a Radio Shack "T" wire tap - small size) - you then run the wire from there up front (along with the camera output wire(s).
