ROTORA Slotted Brake Disc, Ceramic Pad & S.S. Brakelines for the Prius
Discussion in 'Sponsored Commercial Sales' started by Areometer, Mar 15, 2008.
  1. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
  2. KandyRedCoi
    KandyRedCoi S is for Super!
    860
    SoCal/AZ/NV
    nice product, i have a pair of Rotora BBK on my 2000 MR2 spyder and they work superb, when im up for a brake job i will def order me the entire package
    thanx for the heads up
  3. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    WHY????
    Since the Prius only uses the pads in very hard stops and at very low speeds, it seems like the original pads should last almost forever.
    What am I missing here??
    Bob
  4. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    to be ballin in your prius of course.
    with all the money prius drivers saeve on gas, they should throw it away SOMEWHERE:D
  5. KandyRedCoi
    860
    SoCal/AZ/NV
    long story short, not everyone drives their prius like pansies, so theres nothing wrong with better stopping power, and much longer life than OEM
  6. prius729
    prius729 New Member
    120
    Hobbs, NM
    12 pot for a prius is overkill no matter how you drive it.
    Areometer, please check your pm.
  7. KandyRedCoi
    860
    SoCal/AZ/NV
    i was not referring to the 12pot, LOL just the discs, pads, and lines
  8. GatorJZ
    GatorJZ Member
    285
    17
    Gorgeous set up, wow. I have painted the calipers, replaced rotors with zinc plated cross-drilled.dimpled and or slotted rotors, upgraded the pads and replaced brakelines with stainless steel ones (even if I've had to get them custom fabricated) on every car I've purchased for the last 20 + years. The dealers' service departments think I'm crazy, but they look way better and generally stop better with less dust.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    Each to their own.
    Prius brakes will wear out when driving normally but a few people in this world feel they need to change parts of their car even if they aren't worn out. That's fine with me, there is a whole industry based around it.
    Is there a rear disc conversion? Cos' fancy front callipers and rotors are going to look quite odd when paired with drum rears.
  10. the dean
    the dean New Member
    pa
    I also would like to find disc brakes for the rear wheels. I notice the difference in stopping power between my Prius and the other cars I have owned for the past 12 years.
    I respect the Prius for the kind of car it is and do not want to make it something else, but more stopping power would be nice.
  11. hxiong
    hxiong Junior Member
    32
    big brake kit, wow...u got me drowling
  12. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    You can also get shorter braking distances by getting wider and/or better tires. Consumer Reports found that the Touring Prius with its 195/55/16 Bridgestone Turanzas got 10 - 12 feet shorter 60 - 0 mph braking distances than the Standard Prius with its 185/65/15 Goodyear Integrities.
    In my case, I switched to 195/60/15 Goodyear TripleTreds.
