Rotors and calipers at 25,800 miles?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by nednvermont, Jul 15, 2020.
  1. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Hello! I recently brought my 2017 Gen 4 to the dealership from which I bought the car for a standard 25,000 check. In dropping it off I mentioned that I'd been getting a pulsing when stepping on the brakes and wondered if it could be a ABS system problem.
    Answer: "Rotors warped. We recommend replacing all four rotors and calipers" (to the tune of $800).
    Response: "What the...?!"
    I've not had any instances that I recall where I emergency stopped hard which might have heated up the brakes. And, even had that happened aren't brake materials supposed to take that kind of heat?
    With at least 1/3 to 1/2 of those miles being highway miles what could have caused that?? My thought: substandard materials = Toyota problem. Of course the fine print in warranty information would call brakes a normal wear item and might not take responsibility.
    What do you all think? Any others had this problem? Thank you in advance for your thoughts.
    49,507
    i think this is a known defect. call toyota and ask for goodwill warranty.
    you can find other threads here regarding the problem
    amos and nednvermont like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    I think that there is NO WAY that all 4 of the rotors are bad.......and warped rotors do NOT damage the calipers.
    I think you are being scammed.
    Is there another dealer nearby ??
    If you do go to another shop, do NOT tell them what the first place told you.
    You will never get any "warranty" coverage for the rotors that are bad.....maybe only one......but the rest of that is just BS.
    Might want to call the Toyota "warranty help line". They sometimes deal with complaints that are out of warranty too.
    wenreder, amos, KennyGS and 1 other person like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    I'd be going straight to TOYOTA.
    amos and krmcg like this.
  5. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    It's my understanding that a Prius slows down mostly through regenerative braking, and that the actual brakes are engaged only in instances of heavy braking (for an emergency) or at slow speeds (final stop at a traffic light). So I guess I'm wondering when you're experiencing the pulsing - under what conditions. It's been my understanding that under normal usage, Prius brakes last substantially longer than those on standard ICE automobiles.
    Are you using your Prius regularly? Does it sit for long periods? Have you visually inspected the rotors to see if they all appear the same - nothing unusual?
    wenreder and amos like this.
  6. Leadfoot J. McCoalroller
    7,176
    6,728
    Pennsylvania
    2018 Prius c
    A lot not making sense. A need for 4 rotors + 4 calipers is pretty much unheard of at 25k miles, even when there is a part quality issue. Fronts and rears use completely different parts.
    Also, $800 for replacing 4 rotors and 4 calipers at a dealer sounds suspiciously low. I think there are some communication gaps here...
  7. sam spade 2
    7,035
    2,788
    2017 Prius c
    Additional note:
    Most of what is described as "warped" rotors isn't that at all but an uneven surface on them.
    This can be because of uneven corrosion (rust) on the surfaces or uneven wear due to defective rotors......or sometimes due to excessive heat.
    What can warp rotors is improper tightening of the lug nuts.
    Almost NO shop takes the time to do it right.
    Mambo Dave and amos like this.
  8. FuelMiser
    FuelMiser Senior Member
    1,300
    888
    Monument, CO
    amos likes this.
  9. amos
    amos Active Member
    341
    281
    los angeles
    Pulsation can only happen in front wheel rotors. Back wheels are fixed.cant pulsate don't even need any resurfacing.
  10. sam spade 2
    7,035
    2,788
    2017 Prius c
    WHAT ??
    That makes no sense at all.
    IF.....your rear brakes are drums instead of discs, then they are less likely to warp or have soft spots......but not impossible.
    Taken at face value, those statements are just plain WRONG.
    amos and Tande like this.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    A 2017 Gen 4 at 25,000 mile check up needing "Rotors warped. We recommend replacing all four rotors and calipers" (to the tune of $800)".
    You definitely need a second opinion. I am skeptical when it comes to dealerships.
    amos and alanclarkeau like this.
  12. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    My thought: substandard dealership.
    +1 get a second opinion.
    amos likes this.
  13. ChapmanF
    15,664
    Gonna have to offer a bit more of the reasoning on that one.
  14. amos
    amos Active Member
    341
    281
    los angeles
    ok so that statement might seem not right or completely wrong, everybody here knows im not a mechanic and my knowledge is really minimal, im just an engineer.
    of my 40 years of driving experience, i've learned that pulsation of breaks became a major annnoying issue when all disc brakes in front became a standart, will try hard to explain that phisics.
    my thoughts : when disc surface is not smooth than the grip of pads is not perfect same for rear and front, but when front wheels get into a resonance mode, pulsation amplifies itself to a non pleasant point, movememnt of front wheel amlifies that resonance.
    in theory , rear disc pulsation may occur too but there is no amplification of this resonance phenomena, the tolerance of movement of rear wheels is zero,
    also im hoping all experts here will agree with me if i say that there is no need for the rear tires to be balanced, only reason i do rear balance is in case i have to rotate rear to front.
    i will be glad to learn more about that form all members here.
  15. krmcg
    2,592
    2,390
    Whittier, CA
    Tire balance has a direct impact on tire wear.
    Fubar XIII, alanclarkeau and amos like this.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Another thing that can warp the rotors is braking to a stop from high speed (highway) then sitting in traffic (off ramp ?) holding your foot on the brakes. The area where the pad contacts doesn't cool down at the same rate as the exposed area and the rotor warps, especially so in cold or wet weather.
  17. sam spade 2
    7,035
    2,788
    2017 Prius c
    You are trying to discuss two ENTIRELY different things here.
    Tires NEED to be balanced regardless of what kind of brakes are in use.
    Those two things do NOT usually interact with each other.
    A pulsating brake pedal or a feeling of uneven braking causing a jerky feeling upon stopping is a BRAKE system problem.
    Having the car shake while doing down the road at speed is a tire balance problem (or can be).
    No connection between the two.
    And NO you are wrong about not needing to balance the rear tires.
    Unbalanced tires will wear unevenly too.
    Fubar XIII and Montgomery like this.
  18. alanclarkeau
    7,044
    7,584
    What is your AVATAR?
    kithmo likes this.
  19. krmcg
    2,592
    2,390
    Whittier, CA
    MG ZS EV
  20. nednvermont
    nednvermont Member
    67
    74
    Vermont
    Update - I called service manager at the dealership where I bought the car. Same story: "Brakes themselves are a wear item and not covered under the 3 year, 36,000 mile warranty. We're sorry you had this problem but we can't help, other than offer to fix them with a lower-cost, non-Toyota, alternative. Or you can try to see if Toyota Customer Service can help you."
    I called Toyota CS (waited on hold for 45 minutes) and was sympathized with (low mileage/with a bunch of highway miles being a good chunk of those miles), but/and wouldn't budge on any help. "I'll have my supervisor call you." Supervisor calls me, hears my story again, then says he can't help me. His story is the same too, and he passes me to a higher up. Spoke to the "higher-up" at corporate Toyota Customer Service and asked for some good-will warranty help. Told them it felt like they're using substandard materials and that they should be helping me given that highway miles do not wear brakes and I'm not a driver who's hard on vehicles. Same story, "Brakes are a wear item, and while I do hear your frustration we cannot extend a warranty coverage for the brake repair." Then, "Here's what we can do for you: Get the brakes fixed and send us the proof of work done and payment and we'll review this further [to possibly help some]."
    I don't feel good about this... "Toyota, you've let me down. This is my second Prius. I bought this car because I liked my first one and had no problems in the 60,000 miles I owned it. My wife drives a Toyota Yaris with almost 100,000 miles, drives 90% in-town, and just had her brakes done. Seems like Toyota put junk on my car and should step-up." They want me to foot the bill and then they might help. I even suggested that they buy the parts and I'd pay for labor to fix. Didn't budge. Arghhh... I'm bringing the car to my local service shop to take a look on Tuesday.
    Sorry for the "book report" length of rant. And thanks for listening!
    amos likes this.
