Rotors replaced twice in 2 years
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by S_murphy, Aug 25, 2017.
  1. S_murphy
    S_murphy New Member
    Hadley, NY
    2013 Prius c three, 61k. Repair shop had to replace front rotors and pads for second time in just over two years. Love my car but don't want to have to keep absorbing this cost. Research on this topic seems to say this is rare even once with the Prius. Thinking about trading it in. Any thoughts?
    49,507
    welcome!
    maybe your shoppe is taking you for a ride?
  3. S_murphy
    S_murphy New Member
    Hadley, NY
    Dealer actually told me same the first time when was in for routine maintenance. Second opinion told me same. Could I just have a lemon in regards to brakes?
  4. Mendel Leisk
    38,735
    All I can think is to get an independent third party have a look prior to going in, and/or check them out yourself. Especially the rotors, that's VERY likely uncalled for. Over the decades I would replace pads regularly (with regular cars), and never even ocurred to me to replace rotors. I would occasionally check them with dial indicator and micrometer, for thickness, parellism and runout, they were always fine.
    jerrymildred and bisco like this.
  5. bisco
    49,507
    anything is possible i suppose, but we haven't seen that. what we have seen occasionally is rear brake rusting around 40,000 miles because they don't get used as much, and they can freeze the caliper to the rotor due to lack of slide pin lubrication, requiring new pads and rotors.
    let me ask you this, are you having any symptoms before they tell you they're bad?
  6. Mendel Leisk
    38,735
    And does the dealership elaborate, or just tell you it's time again. Seems weird.
    BTW, you should report yourself (report button in lower left corner), this thread is Prius c Maintenance. Prime is for 2017 and onward Prius Prime.
  7. bisco
    49,507
    i did it for her.(y)
  8. S_murphy
    S_murphy New Member
    Hadley, NY
    Brakes started to "grab" when slowing to a stop.
  9. bisco
    49,507
    do you clean the rust off of them regularly?
  10. S_murphy
    S_murphy New Member
    Hadley, NY
    Had the work done at the second shop, not dealer.
  11. S_murphy
    S_murphy New Member
    Hadley, NY
    I do the put it neutral and apply brake technique about once a month. That's it though. Never had issues like this with any other cars. Thanks for the replies!
  12. bisco
    49,507
    sounds good. again, possible that there is a defect, but next time around, i would get a third opinion and ask them to show me what is wrong.
    do you have anyone you can ask, who knows a little something about cars?
    S_murphy likes this.
  13. Trollbait
    11,563
    The caliper pins could be corroded, or their grease simply dried out, and that could lead to the pads dragging on the rotors. They should have pulled them to check and regrease, but they can be left in place for changing the pads and rotors.
  14. Mendel Leisk
    38,735
    Or they're using the wrong grease? Either way, a competent mechanic having to replace rotors twice, doesn't sound good, and in such short order.
  15. ChapmanF
    15,664
    Maybe there's nothing more serious going on here. I wouldn't think of that as a "once a month" (or once-a-whatever, scheduled) thing. They just need it whenever they need it (usually any time after parked for a while in damp conditions).
    Whenever I pull out of my driveway, I can tell if they need it by the rough sound or grabby feel the first time I touch the brakes turning onto the street. I then have three stop signs in close succession, so I just shift to neutral for those, and the braking is always quiet and fine again by the time I'm out of the neighborhood.
    I had to do it the other day because there had been rain. If it rains tonight I'll have to do it tomorrow. If I then don't end up parking in damp for two months, they won't need it for two months. Serves no purpose to do it any time they haven't flash rusted, and conversely, when they have, serves to purpose to leave them that way till next month because that's your schedule. Just notice when you hear/feel the problem and fix it right away. Two or three stops in neutral always do it for me. (I've never experimented to see if it gets harder to fix if not attended to for a month.)
    There is evidence in some past PriusChat threads that some shops (and even dealers, who certainly know better) cannot see past the dollar signs if you drive in with flash-rusted brakes and they think they can sell you an expensive brake job instead of educating you on stopping a few times in neutral as needed.
    -Chap
  16. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    The dealer in Keene NH got my 11 for rear shoes and rotors at 41,000, I knew my daughter had logged 500 miles with the ebrake on, wasn't happy, then at 50,000 I was distracted (just bought a 16 4,) they pegged me for front shoes and rotors, an hour later I had buyers remorse, and I really dislike the service writer, and am glad to speak of it publicly, that's bs, wish I could see a trade magazine, read about service writers boasting about the percentage of fake contracts they get a profit from.
  17. bisco
    49,507
    i was in the plumbing business for 30 years, and never saw any of their devious practices put in writing.:cool:
  18. Mendel Leisk
    38,735
    I find after washing the car and it then sits a day or two, I'll get noisy brakes, due to surface rust. A couple of blocks driving, it clears up, without any special tactics.
    jerrymildred, Trollbait and bisco like this.
  19. bisco
    49,507
    agreed. but when someone says their brakes are 'grabbing' at low speed, something is going on.
  20. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    One of three things... EXTREMELY rusty conditions, EXTREMELY aggressive driving, or the service writers are being very dishonest. Some prii never need brake pad let alone roters replace in their whole life time.
