Rough engine start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, Oct 6, 2009.
  1. bwilson4web
    15,511
    Temperature: 63F
    Time: 1:30 AM
    Humidity: high
    Car unused: ~48 hrs.
    Most recent activity: oil change on Saturday
    Went to run an errand and was surprised at a rough running engine start in my wife's ZVW30. It only lasted 3-4 seconds but it acted as if the engine had an intermittent spark plug failing. Weird.
    Will let the car 'cold soak' another couple of days and see if it returns. I'll also check the spark plug wires and make sure the throttle plate moves easily. For good measure, I'll try to use the iPod recorder on the next couple of starts.
    3 people like this.
  2. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    There have been a couple of reports of "banging" under the hood during cold starts as well. David (blind guy) , I believe was one of the ones that had the problem. Mis-firing could lead to backfiring, which I could see how that would sound like banging?
    On edit, doubt the throttle plate has anything at all to do with it, I would assume no movement of it for idle, and pretty sure each coil pack is monitored so I don't think it could be ignition. I think fuel delivery, maybe even an overly rich mixture due to the evap system and or that charcoal pad above the air filter?
    What are you doing out after midnight?:eek:
  3. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Bob, let us know if you can repeat it. I had that happen once and can't repeat it.
    Wayne
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hi Bob, I had the same thing happen to me once last year with my Gen. 2 Prius. I thought it was gonna rip off an engine mount. O f course it never happened again and there seemed to be no explanation for it. I think the Prius just has a lot of wierd one time things happen to it to keep us Prius chatters from getting bored LOL.
  5. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    Did you by chance, at some point earlier in the day, start the car cold to say move it around on the driveway and then immediately turn it off?
    I've had several cars (non-Prius) run rough the next time after doing this to the point where I don't like jockeying the cars without warming them up (especially in the winter time).
    I don't know what it is, but I'm speculating that it has something to do with the fuel injectors holding a lot of cold fuel that would normally evaporate, but doesn't because the engine is cold.
    Russ s and Econ like this.
  6. bwilson4web
    15,511
    Thanks folks. I had something like this happen with my NHW11 but I was using carb cleaner prior to starting. It was totally unexpected with the ZVW30.
    FYI, it was an errand for "she who must be obeyed."
  7. ecrider
    ecrider New Member
    Maryland
    How timely of a posting... this just happened to my 2010 Prius. I pulled the car out of the garage on Sunday to wash it, and the engine kicked on for about 30 seconds. I turned it off, washed the car, started it back up to pull it back into the garage. The engine again ran fine for about another 30 seconds until it was back into the garage.
    As I started the car Monday morning to go to work, it badly misfired the entire time I backed down the driveway and into the street. It continued for about a block as I drove forward until it gradually diminished and eventually ran smoothly. There has not been a repeat incident since then.
    I didn't do anything unusual when washing it (regular hose washing--no water into the engine compartment), so I was stumped at what might have happened until I read this post. Thanks!
  8. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    Any cylinder misfires would be logged, yes? I can not imagine other events that could cause the extreme symptom that e.g. paprius4030 reports.
  9. FireEngineer
    1,247
    124
    Just happened again yesterday. 6:00PM, ambient temp 60F, engine temp 103F, SOC 4 bars, driven .5 miles. I was proceeding from a stop light and when the ICE kicked in in had a pronounced knocking sound. Not as severe as the first time, but not normal. If your use to a Prius ICE kicking on, when the engine first gets spark and starts you can sometimes feel a very slight catch to the engine, this was worse and continuous for about 30 seconds then just stopped. No indications on the dash and no codes on the ScanGage.
    Wayne
  10. paprius4030
    2,077
    296
    York,Pa.
    I didn't get any codes on my scanguage when it happened to me last year either.
  11. bwilson4web
    15,511
    Your event was longer than mine. One thing for sure about an intermittent problem, it will come back until diagnosed and corrected. I kick myself for not having them look for diagnostic codes when I was as the service center on Saturday. We' re headed for a stretch of cool, wet weather.
    Hypothesis:
    • ethanol impact on cold start
    • slow start problem (past Prius problem)
    • summer-winter blend change
  12. xanmato
    xanmato Junior Member
    31
    Seattle
    I just experienced this over the weekend. I was over in eastside Washington where the overnight temps were about 20F, down from my usual 50F. It happened twice, each in the morning on first start. The first one had me yelling 'whaat thee fuuu***!'. Definitely felt like a normal misfiring on a cold start, but the ICE kept on going instead of stalling.
    Now back in Seattle, I am no longer having this issue.
  13. SJS
    SJS New Member
    Central Virginia
    This happened to my Gen-3 this morning. Last night I pulled the car out of the garage to let my spouse have the Prius' space to load some junk into her SUV.
    This morning I thought the thing was going to shake itself to pieces at startup. Ambient was +/- 50F, very high humidity. No other unusual circumstances other than, as I removed the car from the garage last nite, the ICE ran for maybe 30-45 seconds and the car was subsequently shut off for 8-10 hours before a restart.
    Very curious; I would very much like to know why Prius seem to be susceptible to this.
    (FWIW: I've got ~3,000 miles on it, so it's not like the car's suffered a lifetime of abuse.)
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Everyone the experiences this issue and all the others should report it to the dealer/service department or Toyota directly to get it on record.
  15. FireEngineer
    1,247
    124
    Did that Monday. Tech said he never heard of it. He called Toyota and they said they never heard of it. at least i have a service record of my complaint.
    Wayne
  16. Tlynch
    Tlynch New Member
    St Louis, MO
    Add me to the list of people who have had this happen.
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Had one night where temperatures were below +20 F. and the next morning I had the same problem. Engine was quite rough and it sounded like the exhaust pipe was rattling, lasted about 15 seconds. No repeats but it has been warmer since then.
  18. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    I'll add to the spectrum of conditions. We were gone for 15 days. Upon startup, a WEIRD noise from the engine lasted only 6 seconds or so. Totally unexpected and almost like it never happened--but it did.
  19. dchev
    dchev New Member
    26
    17
    Charlote, nC
    After I washed my Prius tonight, I decided to make a spin around apartment complex where I live. Pushed the start button and a strange noise came from engine.....just of second or maybe 2; however, it made me nervous....
    I opened the hood and check if there is any water on any parts; however, everything was okay.
    Drove the car for 4-5 miles and it seems to be okay for now.
    I will check it tomorrow morning when I go to church...
    I believe it has something to do with temperatures 50F and the fact that I washed it....
    Probably, we will find new interesting sounds in the next a few months....with temperatures going south...
    The Prius is really a unique car :D
  20. a64pilot
    771
    62
    Albany Ga.
    Seems to be a little of a trend. Moving the car or running it for just a short time, then turning it off and starting it the next day seems to aggravate the condition. I'm sticking to my too rich a mixture theory, but to be honest too lean would do it as well. Don't think it is ignition or any other electronics as that should throw a code.
    Most likely will end up being a anomaly of the car, just something they can do from time to time.
    Skykid2 likes this.
