Rough idle and triple icons on start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by meyou, Feb 2, 2016.
  1. meyou
    meyou Junior Member
    Lafayette, LA
    I left the car in ACC for a few hours on Sunday and drained the 12v battery.
    Had a friend jump me off and said friend hooked the jumper cables up backwards on his car (stupid + sign water caps). It blew the fusible link.
    FF to today I get the new fusible link installed, hook the jumpers up the right way, and the car starts right up. A few seconds after startup I get the big red triangle and three icons on the display, battery symbol, car with ! in the middle, and another battery symbol that says "MAIN" underneath. At the same time the engine idle became very rough and jerky.
    I found another thread here about these symptoms after a battery swap cause by the ECU switching to defaults and the fix there was to power the car on and immediately shift to neutral and let it idle for awhile. I tried that for like 10 minutes twice and nothing has changed.
    If I power it on and put it in reverse, I can back up normally. If i switch to drive, the gas pedal doesn't respond at all and I just creep forward very slowly from idling.
    Any suggestions for a home remedy for this, or if dealer service is required, how much I might expect to pay?
    edit: Pulled codes:
    P0A80 Replace Hybrid Battery Pack
    P2118 Throttle Actuator Control Motor Current Range/Performance
    #1 meyou, Feb 2, 2016
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
  3. meyou
    meyou Junior Member
    Lafayette, LA
    Woops I need to update my location on here. I'm in Lafayette, LA now.
    51,154
    if you want to diy, you will need mini vci and an old windows laptop. tough to diagnose over the phone, but a good local mech could get you into some salvage parts reasonably. you may want to pay the dealer diagnostic and go from there. post the codes here for advice.
  5. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Well, I don't know who you would call in Lafayette. Sorry.
  6. bisco
    51,154
    is houston too far?
  7. meyou
    meyou Junior Member
    Lafayette, LA
    bout 3.5 hours for a car that doesn't drive, yeah
  8. meyou
    meyou Junior Member
    Lafayette, LA
    I pulled the codes and I've got these two coming:
  9. bisco
    51,154
    what's going on with your 12 volt?
  10. meyou
    meyou Junior Member
    Lafayette, LA
    I don't have a multimeter and the thing doesn't want to go into diagnostic mode. It seems like the computer is rebooting or something, when I press and hold info the screen goes black before I've done the headlight flipping and then back to the prius boot screen..
  11. bisco
    51,154
    any idea how old it is? there's a date code on the top.
  12. meyou
    meyou Junior Member
    Lafayette, LA
    The 12v in the trunk? I replaced it myself about...2009
  13. bisco
    51,154
    since you drained it, and it is 6-7 years old, it would be worth testing/charging/replacing. even though your codes are for other problems, a bad 12v can confuse the computers. so start there, and then move on.
  14. meyou
    meyou Junior Member
    Lafayette, LA
    So I connected jumpers again and left my Prius off while my jumper car ran for like 10 minutes. After that I was able to get into diag and it was showing right at 12.0v/11.9v when I first looked at it. Over a few minutes it gradually dropped to 11.6v while I explored the diag menus.
    When I start my engine it jumps to 13.9v and the engine sounds good, then after a few seconds it drops down to 11.5v and at the same time the engine starts sputtering and trying to die on me.
    Going to autozone to return their code reader and test the battery in a bit...
  15. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    Battery is toast
    If reader is not Prius aware it will not give you the proper error codes
    Buy or borrow a MiniVCI if new battery does not correct your issues
    #15 DRACO, Feb 2, 2016
  16. meyou
    meyou Junior Member
    Lafayette, LA
    Well that's embarassing. 10a ETCS fuse causing the engine to misbehave. Replaced that and the car is running fine, but still have the error codes and autozone says the battery is bad, although good enough to start the car and drive around without any perceivable problems. Now to find someone to sell me a Prius battery that's not $225 Optima
    Thanks for all the help everyone. To anyone who stumbles in with a similar problem, always check all the fuses and not just the fusible link when you reverse jumper cables!
  17. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Exide FP-AGM51JIS is another option, if you can find it locally for about $165, get it. Otherwise, you can get it at the following for $149 plus about $15 dollars in shipping.
    Exide AGM Car Battery (Group S46B24R)
  18. bisco
    51,154
    that's about as good a price as you will get. generally 160. to 180. for aftermarket. check dealer prices and ask about discount coupons.
