Rough idle, low milage
Discussion in 'Gen 2 Prius Main Forum' started by Verylargeboots, Oct 25, 2017.
  1. Verylargeboots
    Verylargeboots New Member
    King George Virginia
    I have a 2008 Toyota Prius Touring with 181,000 miles on it. Recently I had some issues that I thought I had resolved by changing the spark plugs out. The CEL went away for a few months, and then came back on, throwing P0300, P0302, and P0304. I changed the ignition coils for cylinder 2 and 4, and the issue abated until yesterday. It is currently throwing the same codes listed above. In addition to this, I have a rough idle on startup. Any assistance or advice would be greatly appreciated.
    49,371
    what the 'low mileage'?o_O
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    A car with that many miles has had a lot of gas run through it. Have you checked the fuel side of the equation like the injectors?
  4. Verylargeboots
    37.4 mpg on average. I have not looked at the injectors yet, I was hoping to figure it out before going into something more labor intensive. Would you recommended using an injector cleaner like Chevron before pulling the injectors?
  5. fotomoto
    5,602
    3,778
    So. Texas
    Yes but it will most likely take a few tanks to see the full benefits.
    Other possibilities, a faulty crank or camshaft position sensor throwing off the timing.
  6. Verylargeboots
  7. bisco
    49,371
    have you checked all the usual culprits like tires, filters, 12v, and etc.?
  8. Verylargeboots
    Tires are good, not great. I'll change all 4 and all 4 tpms sensors in December when they get closer to needing to be changed. 12v is fine. As for the filter, other than the cabin filter, and the air filter under the hood, what else should I look for?
  9. bisco
    49,371
    that's it. make sure you get good low rolling resistance tyres, and keep the pressures up.
  10. Verylargeboots
    Awesome sauce. I'll post after a few tanks and either habe a resolution, or go back to the drawing board
  11. Verylargeboots
    Update: After 4 tanks of gas , one with the Chevron cleaner, zero problems. However, I also switched brands of gas, from Sheetz, to a Top Tier approved gas, like Valero. I actually switched brands in all my vehicles, and noticed that they all run much smoother now. Idle is no longer rough, and so far has thrown no codes
  12. SpaceCityHybrids
    38
    52
    Houston
    Use Techron right before you change your oil.
  13. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    I don't think those can cause those codes yo come up
  14. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    These are what I think could cause the problem:
    1. On the fuel system side, ensure the injectors aren't clogged with carbon deposits; fuel pump pressure shouldn't be low.
    A system that's too lean in fuel supply would cause the problem, there's less fuel going to the system.
    A weak pump can also cause it.
    2. Engine side, check to ensure your valve cover gasket, isn't brittle, and letting in oil in to the plug holes, and flooding the centre electrode of the plugs. If they do, you'd have codes.
    3. Replace all the spark plugs, if they're worn already.
    4. After you've done all that, and the problem persist, have the electrical circuitry on the number two, and four replaced.
    5. A dead or failing injector system, would cause the problem you make o
  15. Hoho
    Hoho New Member
    Santa Barbara
    So do you believe that it was the gas that caused it? I just do not understand how gas goes bad - I presume that there is pretty high QC with refineries. But then again, I have definitely gotten a tank of gas somewhere, had CEL come on and the car ran rough until the next station, filled up and then everything was fine.
  16. Verylargeboots
    Hoho: I have no idea if this is the reason, to be honest. However, I still have no codes thrown, and none stored since switching brands. This is my assumption since other than the aforementioned maintenance, nothing else has been done to the vehicle. I do know that the gas is mixed with ethanol at the station, and that may have something to do with it.
