Rough idle/misfire and dealer blamed on cheap gas...?
Discussion in 'Gen 2 Prius Main Forum' started by 4G63, Feb 2, 2010.
  1. 4G63
    4G63 I quit boosting
    147
    Aurora, IL
    Our 2008 Prius has been having this minor rough idle issue for a while. I can feel the engine being lumpy when the car is stopped and the gas engine is running. No matter if the engine is new or cold. It even happens when I just get off the highway. And now it's becoming more frequent. Considering this is not normal since our car has normal miles on it (22k), I took it to the dealer today to check it out and got an oil change.
    They ran a diagnostic and couldn't find any code. Well the check engine light is not on. But they determined there's a very slight misfire. Then he asked me what kinda gas I put in and I told him just regular unleaded. I'm not loyal to any gas station so I just get gas when I need gas. Then they asked me to burn the remaining tank and put premium gas from some big, reputable gas station (BP, Shell, etc.) in it and see if the problem persists.
    Isn't the Prius' engine designed to run on regular unleaded? If I put premium gas in it this time and it fixes the problem, that's good. If not, the dealer wants me to bring it back. But if I need to put premium in it in order to get a smooth idle, that's not going to happen.
  2. chuckknight
    chuckknight New Member
    194
    33
    I've found my baby runs much better on real dino-fossil fuel than on ethanol, and that the cost is comparable. It actually gives me better mileage, too!
    Bad gas could make for a rough idle...or at least it did in every other car I've had. Their suggestion has more to do with the consistent quality of the big name brand gas stations, than anything else.
    Having said that, the Prius is so sophisticated that it can adjust to running on any crap they decide to push on us.
    *Really* rough could imply a problem. A little rough could imply bad gas.
    Chuck
  3. Patrick Wong
    18,200
    6,472
    The Prius engine is designed to work on 87 octane unleaded gasoline. In fact the Toyota tech training docs indicate that the engine may have starting issues when higher octane fuel is used. See p. 3-4 of the Hybrid13 Fuel and EVAP System.pdf file that you can find in the Technical Articles section of this website:
    Automotive Training and Resource Site
    It could be that the advice was given in hopes that one tank of premium gasoline may help to clean engine deposits. An alternative would be for you to buy some Chevron Techron and add that to the tank when you next refuel.
    There's something to be said for buying gasoline from a name-brand station, though, in order to obtain the additives that may be missing from gasoline sold by a no-name place.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I second the Chevron Techron. I use it on a semi regular basis in our chevy Venture since it helps keep the different things in the fuel sender clean (a GM issue), but recently put in a bottle in my Prius since I thought it idled very slightly rough. It seems to have done the trick since my Prius purrs like at kitten at idle now.
  5. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    The Prius ignition timing is tuned for 87. Running higher octane will result in decreased performance and a rougher idle.
    Your dealer is an IDIOT for suggesting that you use premium given that:
    1) It costs more.
    2) Will decrease performance.
    3) Will decrease gas mileage.
    4) Will add to carbon build up.
    Always run the octane your vehicle is tuned for to get optimal performance.
  6. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    Had a similar problem at the end of a cross Canada trip a year ago. However they were able to pull a code which indicated "misfiring".
    The mechanic suggested I picked up some water so I added 1/2 container of STP water removal and have not had another problem. My local dealer said he had a customer with a similar problem which continued for some time until he changed where he bought his gas.
    Gary
  7. 4G63
    147
    Aurora, IL
    I think i'll just get a tank of regular from a better gas station and try some fuel additive. but still that's a very sensitive engine.
  8. a_gray_prius
    2,927
    782
    IL
    That's really interesting because my Prius seems (I emphasize seems) to run better on 93 octane (I run a tank through every once in a while). Specifically, the engine appears to run somewhat more quietly with a smoother rev response. Again, this is a very superficial seat-of-the-pants impression (added to calm the apparently now-rabid Prius fanboys).
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You should try a blind test. Have your wife or coworker fill your Prius the next four or five tanks. Have them switch between 93 and 87, but don't tell you which is in the tank. Write down your results. At the end of the trial, you can compare your perceptions with reality and see if there is any correlation. No cheating!
    Tom
  10. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    Interested to hear more feedback, as my car just started doing this at idle too.
  11. mike lipke
    mike lipke New Member
    89
    MN
    try the Techron first.
    It is a very strong (good) fuel system cleaner. Much stronger than whatever little bit might be added to premium fuel.
  12. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Have the plugs checked. While doing that they can inspect to see if the plug inserts are leaking allowing water in there. This was a known problem and I'm surprised the techs. didn't check that (well not really after what the dealer told the OP).
    I find that E10 cleans up engines quite well and also ensures there is no water pooled in the fuel tank (it absorbs it and allows the engine to "burn" it). You do get a mileage hit. I've switched now to only using a tank of E10 once every two months. So that's one every four or so tankfulls.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Thats what I was thinking too. To the op:
    Has the car been in very heavy rain and or a carwash where water may have gotten into the engine compartment?
    There is an issue where water can get past the water dam tray below the windshield and leak over onto the top of the engine and get into the spark plug wells. There's 4 rubber boots on the top of the engine over the spark plugs that are the plug igniters. If water gets in a well it will fill up the well and short out the igniter possibly intermittently. Since it will cause a certain misfire it usually throws a check engine light. If you do get a check engine light in the future make sure you get that code it throws from the dealer when they pull it and let us know what the code was.
    Also be careful when washing the car at home. A strong stream of water at the wrong angle can allow alot of water to enter the engine compartment. So after a good carwash always open the hood and check the engine.
    When I first bought my Prius the wife put in a few tanks of premium fuel by mistake. The car ran really good on it just got bad fuel mileage. But no perfromance issue at all.
  14. David Beale
    5,963
    1,981
    Edmonton Alberta
    Whenever I wash my car at home (spring to fall) I also wash the engine. Have never had water get into the spark plug wells, but I do believe those who say it can. I don't use a pressure washer at home. I use a garden hose.
    My understanding was that the leaking spark plug wells were "fixed" after some model year, possibly 2005. Don't know that for sure so don't quote me.
    Even so, stumbling idle would make me very suspicious of them.
    Check the plugs or have them checked.
  15. sktn77a
    sktn77a Member
    294
    NC
    Higher octane gas won't result in decreased performance or rough idling. But it does cost more and shouldn't be necessary in a Prius which is designed to run on 87 octane.
  16. edthefox5
    10,096
    4,805
    Clearwater, Florida
    I can confirm this also. In fact my 07 ran very good on it. Very peppy pickup. Just did not get very good mileage.
    Now I'm not advocating running higher octane as many times mentioned its tuned for a lower octane which is exactly what I run.
    Do not run Premium!
    But by mistake it did see a few tanks of Premium when I bought it
    years ago with no performance issue at all.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I would approach this as a step by step process. I would agree with those suggesting the easiest first step would be to try a tank of Top Tier Station Premium Gas.
    I would also then fill with a Top Tier station regular and add a bottle of Techron..run it through.
    See if any of this helps.
    I can understand not wanting to go to Premium permanently, but if you have build up or deposits running some techron through might clean it up. Then you could go back to regular.
  18. Mendel Leisk
    38,711
    Your car doesn't need higher octane, however, there are few incidentals about higher octane gas choices: they tend to have less (or none, with Chevron's top octane choice, for one) ethanol blended in, and more cleaners (Chevron again).
  19. richard schumacher
    7,663
    1,038
    United States
    Check for a dirty MAF sensor. This shouldn't be the case at only 22k miles but the symptoms seem consistent with it.
