Rough idle
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Oct 24, 2020.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    02 has rough idle and no radiator fan when AC is on. Which relay is for fans. Code 117? Thanks
  2. Trombone
    Trombone Member
    195
    69
    Allentown, Pennsylvania
    2002 Prius
    Code 117 means HV ECU back-up power source circuit malfunction. It is a sub-code of DTC P1600, BATT Malfunction, one of the Hybrid Vehicle ECU Diagnostic Trouble Codes. As for the relays, see the Owner's Manual, and also look inside the covers of the relay boxes under the hood, where they are identified by location in the relay boxes.
  3. bigblock67
    171
    35
    Indiana
    2002 Prius
    Is there a video on Gen1 temperature sensor unit R&R?
    Thanks
  4. Trombone
    Trombone Member
    195
    69
    2002 Prius
    Google "2002 prius temperature sensor unit" and you'll get a few hits!
