Rough start 2015/52K
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Priushunter, Mar 18, 2019.
  1. Priushunter
    Priushunter Junior Member
    Philadelphia PA
    I've seen several posts on here about rough starts in older model years but I have a 2015 Prius III with 52K miles that we purchased certified pre-owned about a year ago. This morning and maybe two other times over the few weeks, I've experienced rough starts for a few seconds after the gas engine kicks in. They've always been on cold starts, but not at super low temperatures and not when it's humid or raining. I've still got about 3K left on this oil change and the last maintenance check was in November. I'm going to try some injector cleaner just as a first line option, and it would be great to get your thoughts on possible problems before I take it in for evaluation and possible service. Thanks in advance.
    49,498
    are you starting the car for a short time, like moving it in the yard, and shutting it down with the engine running?
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Egr circuit needs cleaning and oil can installed
  4. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Put that cpo title price into use, take it in the dealership.
    RMB likes this.
  5. Priushunter
    Philadelphia PA
    No, it's been when I'm heading to work in the morning. Usually a 20-30 minute drive.
  6. Priushunter
    Philadelphia PA
    Unfortunately it's out of the original warranty and we didn't opt for the extended because a lot of threads on here advised against it. Do you think it's a possibility I can argue that something like this shouldn't be happening if it was CPO or what do you suggest?
  7. Priushunter
    Philadelphia PA
    I asked my husband and he did move it to another parking spots once or twice on recent nights. I'm not 100 percent sure it was the nights before it happened, but do you think this could be the reason?
  8. bisco
    49,498
    it is definitely a major cause. best practice is to wait for the warm up cycle to finish. when the engine shuts off, you can power off the car.
    RMB likes this.
  9. Triparadox
    Triparadox Active Member
    201
    108
    I hope you're not getting a problem with head gasket like I do. Rattling when starting up. But everything goes smooth like no problem when driving.
