Rough/stiff ride after new struts/shocks
Discussion in 'Gen 3 Prius Main Forum' started by markjosh51, Nov 14, 2019.
  1. markjosh51
    markjosh51 Junior Member
    42
    North Hollywood
    I have a 2014 Prius two and last week I replaced the struts and shocks with KYB and at the same time I replaced my tires with Bridgestone Ecopias 422 plus. Although the steering and stopping have improved the ride seems rough especially when I go over speed bumps. Do the struts and shocks need to be broken in?
  2. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    There is breakin period.
    Also, since you got new tires, the place probably set your tire pressure to 40 psi.
    Higher tire pressure = more bounce, coupled with new shocks.
    iPhone ?
    edthefox5 likes this.
  3. markjosh51
    42
    North Hollywood
    40 psi? Isn’t that going to wear out the tires quickly?
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I’m running 44psi and all 4s since they were new. The wearing is on schedule to meet the 80,000 mi spec., even les schwab tires says the same when I physically let them do the rotation, said tire wear is on schedule. But I don’t drive like a maniac to be the first one at the next stop light, I drive like my avatar :p
    Pluggo likes this.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I wish. Tire places are not to over inflate tires pass the driver door jab manufacture specs.
  6. bisco
    52,731
    non oem shocks and new tires, tough to compare to worn oems.
    how many miles on her?
  7. markjosh51
    42
    North Hollywood
    166,500 mi. I thought the KYB struts were the oem part.
  8. markjosh51
    42
    North Hollywood
    What would be the break in period? 1000 miles?
  9. bisco
    52,731
    you may be right, i didn't realize that
  10. markjosh51
    42
    North Hollywood
    when I went to my mechanic I told him if I can put on Monroe but he advised me to put on KYB. I assumed that these are the OEM.
  11. bisco
    52,731
    okay, i am not sure. call a toyota parts dept and ask
  12. George W
    George W Senior Member
    934
    519
    San Antonio
    Mind the tire specs. While the door jamb may say 35 psi, the tires may suggest something else. I bought 4 recommended tires from Discount Tire, for my Gen 2 Prius. The PSI rating on them is '30 to 52'. The car is sluggish at door jamb, but normal at 40. I'm not sure why these are a 'recommended product' for my Prius, but the wear is even all around, and mileage is typical at the higher psi.
  13. bisco
    52,731
    the door jamb is the factory rec.
    the tires have minimum and maximum parameters.
    but these two can conflict as ford and its tire supplier found out with the explorer
    TheeWood likes this.
  14. tonynap
    tonynap Member
    43
    38
    NY
    I had the same experience and think it's the jump from 89H to 91H tires.
    I used Goodyear Assurance Fuel Max and Bridgestone Ecopia EP20 which both had max sidewall pressure of 44 psi, and that's what I ran them at. I never had any issues with ride or wear.
    I replaced rear shocks, front struts, and tires simultaneously. The new tires have a max sidewall of 51 PSI but running them at 51 PSI is out of the question. It's like riding in a covered wagon. You feel everything.
    This is what I did and is my advice to you. I ran them at 35/33 (the door) for a tank and checked the MPG against the last tank. It was not as low as I thought it would be, and the ride was as pretty mushy as you would expect. I went to 40/38 for a tank and got very close to the MPG I previously got. The ride stiffened noticeably.
    At some point I got to 44/42, got the same MPG as pre-change, and no noticeable change to the ride.
    George W likes this.
  15. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    About 1 week.
    iPhone ?
  16. markjosh51
    42
    North Hollywood
    so 40/38 psi? Are the tires wearing out evenly?
  17. Mendel Leisk
    42,211
    There's a pressure embossed on every tire sidewall, indicated as max pressure at max load, something like that. As far as I know the tire manufacturers recommend you follow what the car maker says. What is that 35/33 (front/rear)? The main "jimmying" I'd do with that is to just set all four to 35
  18. markjosh51
    42
    North Hollywood
    I don’t like using the manufacturer tire pressure because it makes my car sluggish. I currently use 36 psi all around.
  19. Bojar
    Bojar New Member
    Alhambra, CA
    2013 Prius v wagon
    I have a 2013 Prius V 3, and recently put KYB struts and shocks on my vehicle. The ride is now terrible. Worse than before the change. I am feeling everything on the road. The supplier is refunding me the cost. I brought the parts to my mechanic to install. Has anyone have a good experience with a different manufacture's products? I want a good ride.
  20. Mendel Leisk
    42,211
    Plus one pound, that'd get lost in the noise, lol.
    Grit likes this.
