Rubber between window ripped
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, Jul 17, 2021.
  1. kehyler
    kehyler Member
    84
    32
    blah
    HI Guys,
    I had a rubber seal between my window and my door rip. Anyone happen to know what the part number is for replacement and also what the process is?
    -kehyler
  2. ChapmanF
    18,839
    If that's the left front door (I'm trying to guess from the photo, as you didn't say), I think the part should be this.
  3. JC91006
    16,896
    8,629
    This happened on my 2010 and I replaced all 4 doors, you will need all of them
  4. ChapmanF
    18,839
    You do mean you replaced the belt moldings on all 4 doors, right? :eek:
  5. kehyler
    kehyler Member
    84
    32
    blah
    If you don't mind, how does one replace them?
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    They just clip in place. I pulled out all four on our Gen 2 a few years ago. I just grabbed one end with needle nosed pliers with the window all the way down. New ones push into place. As I recall, there's a clip on each end and the rest kind of snaps in there.
    #6 jerrymildred, Jul 17, 2021
    JC91006 likes this.
  7. JC91006
    16,896
    8,629
    oh yes, 4 belt moldings. Don't want people to think I went to get 4 new doors LOL
    jerrymildred and Raytheeagle like this.
  8. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    not bad. Some feller had an issue with his turd gen key fob, his quick fix was buying a new prime.
  9. JC91006
    16,896
    8,629
    You can just rip out the old one any way you can, the new ones will slide in and clip into place.
