Rubbery sorta foul odor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ernie1, Nov 2, 2008.
  1. ernie1
    ernie1 Junior Member
    67
    Sacto,Ca.
    My 2008 Prius Touring sedan has developed all of a sudden, a rubbery sorta foul smell and it seems to be coming from the vent at the rear passenger side door area. My understanding is that it's the vent for the battery and allows it to vent heat? Whatever. Do you think something is failing or is this a maintenance/repair issue? It gets worse after the car is stopped and doors closed for awhile. Car has 11,000 miles and no trouble lights are on and it seems to be running fine otherwise.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    I smell nothing but plastic out of my 07 13K car battery vent. You are correct that is the vent for the battery cooling fan. Has it been blocked? Vent/fan blades clean? Heard that fan come on? What is the soc (state of charge) of the hybrid battery? Is it charging up properly? I would take it to the dealer immed. and have them take the cover off back there and look at the pack assy. if I was you but it has not developed into a big problem yet as any hybridpack/charging issue would throw a DTC. Good luck and report back please.
  3. ernie1
    67
    Sacto,Ca.
    I'll report back when I find an answer. I'm not sure if I've ever heard the fan running. Should I? SOC I guess is reflected in the bar graph with the yellow bars?
  4. edthefox5
    10,096
    4,804
    Clearwater, Florida
    No I think you should never hear the fan unless your doing super duty with the car.Running very high outside temp with windows down....really pushing the car with load up & down mountains etc.
    SOC is battery charge level. Its on that same page but its the box with the blue bars.
    That box is hybrid battery capacity. Yellow bars are power flow. Hybrid battery pack is the box with blue bars. Should always have blue bars in it. Most always. 2 purple bars are its near depleted. You'll see that in hot stop & go with AC on but should charge right up once you get going along. 5 green bars its full.
    Its computer algorithm is it will not allow you to fully deplete it. It will not allow it to get more than 80% depleted and conversely it will never allow it to get more than 90% charged for proper batter maintenance. This is invisible to you and will just show you 5 green bars for fully charged. Unless something has gone horribly wrong but you'll know it will throw codes.
    Only thing I know for sure with this car is unlike any other car if it throws a check engine light of any nature do not drive it till you understand its fault as you can do alot more damage motoring along with a fault.
    Good luck.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You shouldn't hear the fan running unless the battery is quite hot...very hot summer days usually.
    While the vent you're referring to is for the battery it's the air intake for it. If the battery got hot I guess it could vent fumes that way.
    Other things to check...
    1) Pull your cabin air filter and make sure there are no mice in it...or mice by-products.
    2) Do you hear any sloshing when turning? If so, sometimes people get water in the drain channel under the hood by the front windshield and it can get pretty rank and require a good cleaning. I think this is most common for people who park outside.
  6. ernie1
    67
    Sacto,Ca.
    Update on odor problem: I think the mystery has been solved. It's an odor that started after someone with some strong smelling cologne sat in the car. I think some sort of chemical reaction occurred because the foul odor sure didn't smell like cologne but it has been less apparent in the last couple of days to a point where it seems to be gone. I'll keep my fingers crossed and thanks to everyone for their response.
  7. perryma
    perryma New Member
    1,781
    Tennessee
    My car has a mystery stink bomb every now and then and it has been reported by others (check the threads). I think mold, etc can build up in the air duct system or something like that. I tried everything including having my carpets shampooed, mold killer in vent system and it always came back. My latest trick seems to have worked. I noticed the carpet on the passenger side had a bit of a smell but that wasn't the ghost smell I was getting. I bought some Arm and Hammer Carpet & Fabric Fresh odor eliminator. I opened the hood and sprayed it into the air intake vents by the wiper blades and had the ac on high while doing this. After it ran for a while, I turned off the car and I sprayed my carpet (check for color fastness) and then I sprayed it into my air vents and into the interior cabin air filter area-without filter) and then put the filter back in). I let that set in the vents all night. My car was fresh as a daisy the next day. I have done this twice now and it is killing something and working. You just wouldn't want the stuff to be spraying out on you. Give it a try!
  8. ernie1
    67
    Sacto,Ca.
    perryma:
    Good suggestion. Think I'll try that tommorrow! Thanks!
  9. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Great Suggestion. My wife is always complaining about moldy smelling air with the AC on. I'll try it!
  10. CAH
    CAH New Member
    Virginia
    I have a similar problem with my 2006 Lexus RX400h. I bought the car used and did not notice the odor until it was too late. It is a chemical smell that puts me in mind of outgassing of some material. Some describe it as the smell of peppers (e.g., spicy peppers in Thai food). Recently, I attempted to track down the location of the odor by sniffing around. It appears to be coming from the battery vents located under the rear seat. I also sometimes detect the odor when I get out of the car. One suspicion is that it is outgassing from the battery, perhaps due to a breach in the casing, but this is mere conjecture and I haven't anything to back it up. Does your vehicle still exhibit the odor and have you found the problem? Thanks.
  11. Glyn Williams
    Glyn Williams New Member
    Charlotte, NC
    I have been looking for a solution to a similar problem for months. I know your post is old but have you been able to resolve the issue. I have a 2009 Camry Hybrid with 72k and I started experiencing the "funny odor issue" about 6 months ago. I tried every type of deodorizer I can think of and it kept coming back. About 2 months ago we started noticing the same smell when we got out of the car. The smell outside does not linger. The smell inside can get very bad. In an instance a few months ago driving from Atlanta to Charlotte the odor got so bad I experienced a headache! That evening my wife and I went out so she could verify it. She did but after the car was off for 45 min. and we started driving again the smell was totally absent. It is now to the point that I can not drive the car without the smell being apparent inside and out.
  12. bisco
    49,387
    sounds like you've got the O without the B! have you tried the dealer?
  13. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Hi Glyn. While it's not a particularly common problem, something very similar to what you describe has been mentioned by several others here in the past.
    See for example this thread here : http://priuschat.com/forums/gen-ii-...car-has-new-car-smell-again-after-2years.html
    Look in particular at replies #8 and #9 where they seem to really pin down exactly where it's coming from and what is causing it (degrading rubber vent tubes in the HV battery).
    Hope that helps.
