Rubbing/Squeaking Noise when first moving.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by captainkoopa, Oct 12, 2024.
  1. captainkoopa
    captainkoopa Junior Member
    2013 Prius Plug-in
    Had a look through the threads and haven't found anything touching on this issue - I'm sure it's not an isolated PIP issue, but every time I start up my car and leave, there's this weird noise that I can't put my finger on.
    Goes away after a few seconds to a minute. Any thoughts on this would be appreciated.
    There is also a bit of a squeak from the brakes going at a slow speed but doubt this is related. And there's a bit of a clunk when going over bumps - not sure if this is related either.
    Thanks!
    51,088
    not the pedestrian alert system?
  3. captainkoopa
    2013 Prius Plug-in
    The EV ghost noise thing? No, definitely not that. I'm thinking it's something rubbing in the rotor or a bushing
  4. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    opps : see edit
    do you know - either - what to look for in the brakes to determine if they are in need of service
    Or a mechanic you trust and will explain to you what will be done to the car if the brakes really are in need of service.
    edit:
    when did these noises start. Is there brake service listed on any of your service invoices recently?
