Rules of Thumb for Driving Hybrid Cars
Discussion in 'Gen 3 Prius Fuel Economy' started by Anas Almustafa, Jun 16, 2015.
  1. Anas Almustafa
    74
    28
    Arbela, Irbid, Jordan
    This is a video about my experience driving toyota prius hybrid cars for the past 5 years. i hope it helps, any feedback is highly appreciated :)
    I just made a video about how to drive toyota prius hybrid cars taking into consideration battery charge level and road terrain. Toyota Prius Driving Guide with respect to Battery charge and road terrain
    51,493
    that is very helpful, thank you!(y) again, well done.:)
    Anas Almustafa likes this.
  3. Anas Almustafa
    74
    28
    you are welcome, thanks
  4. kutztown46
    kutztown46 Junior Member
    31
    Kutztown, PA
    2022 Prius
    Question: When going down hill, is it better to do some braking to increase the battery level as the video suggests, or is it better to coast and build up as much speed and momentum as possible if there is an uphill segment coming soon?
  5. bisco
    51,493
    it's best to brake if necessary to stay at speed limit. if not reaching speed limit, don't brake.
  6. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    That depends on the length and steepness of the hill. On short downhills, your latter option (with not even regenerative braking), assuming speed doesn't reach an unsafe level. On medium-sized hills, you might as well store some energy part-way down, then coast the bottom part to build speed for the next uphill. On still larger hills, the battery may run out of capacity, so you'll have to resort to "B" mode or friction braking.
  7. bwilson4web
    16,113
    Just a couple of comments:
    1. Charging the traction battery causes it to heat up. When I'm descending tall hills, ~500 ft / 110 m, I prefer to use "B", especially on steeper grades. The battery will still get an acceptable charge but it won't be 'heat pumped.' It also lets me keep feet on the floor when descending a 8% grade hill.
    2. Pulse-and-glide in traffic is less efficient than just finding some slow traffic to follow. Speed and excessive accelerations are the enemy. So when following slow vehicles, traffic coming from behind will see the Prius stuck behind the truck or trailer and smoothly pass. Meanwhile, you're driving is a very 'low stress' mode. I typically just control my speed with the cruise control, patting up or down makes a 1 mph change, up to three can be stacked. But if your driving needs to be more stressful, 'pulse-and-glide' will keep that heart rate up . . . especially if there is a woman in the car. <grins>
    BTW, I especially endorse #6 and #7. When you borrow energy from the traction battery, it has to be replaced by charging. One of the characteristics of NiMH batteries is this is an exothermic reaction, more than just ohmic heating. Let the engine do the work and keep the traction battery cool. Just remember, a badly done 'pulse' can draw on traction battery energy so I'm lazy and prefer to let cruise control handle the speed.
  8. Anas Almustafa
    74
    28
    I'll let the car pick up speed and momentum first on downhill slopes then slightly press the brakes to fill up my battery and sustain my momentum and speed. If the battery is fully charged then i'll just pick up as much momentum as possible to get over the uphill with minimum fuel.
    don't exceed speed limit :)
    Is there a speed limit on the "B" Gear ? I seem to not use the "B" mode at all unless it's a very steep uphill or downhill
    #8 Anas Almustafa, Jan 1, 2016
  9. Mendel Leisk
    40,934
    B mode is intended as a preemptive measure, to forestall the battery becoming fully charged on long downhill runs. Coming down a ski hill for example.
    That's the only time I use ours. Did just that xmas eve. Don't much like dragging the car up there, suspect it's tough on it. Who knows.
    Here we are in the parking lot, kinda socked in:
  10. Anas Almustafa
    74
    28
    ya, i can visually see when you would need the B mode now :) Tire chains for a prius are a must in this type of snow too.
    Happy New Year and i hope you had a great new year's eve.
  11. Mendel Leisk
    40,934
    Yes, best to you too. Hope for peace!
  12. kvkasun
    kvkasun Junior Member
    Sri Lanka
    great work mate
    useful video. thank you very much
