Rumbling noise from 45 to 55
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jan 14, 2017.
  1. Taxi/Limo
    Taxi/Limo Active Member
    509
    107
    Hello All
    When I get on the freeway at about 45 I start to hear what sounds like a little motor at high rev coming from the left rear area of the car (or it could be described as a rumbling noise) it is at its loudest at 55 and goes away as I approach 60 mph
    To review pretty loud rumbling noise starts at 45 goes away at 55.
    Is it alignment or tire balance or maybe a rock in the tread?
    Thanks
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Wheel bearing
  3. Taxi/Limo
    509
    107
    It has just at 57,000 miles and it's a 2010 do wheel bearings go out that soon?
    Nexus 6 ?
  4. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    Not normally, but it seems to fit. I wouldn't rule it out. I can also imagine some sort of tire defect that that only makes that sound at certain wheel rpms. In my experience, a rock in the tread makes a clicking sound at low speed on pavement, especially with an open window.
  5. grnd0
    grnd0 Member
    42
    26
    I replaced a right rear on my 2010 with 55,000 miles.
  6. bisco
    49,692
    2010's are notorious for early wheel bearing failure, albeit, still a very small number.
  7. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    If it's a mis-balanced tire(s), you would get vibration....are you experiencing this?
    Sounds like a worn bearing to me.
  8. Taxi/Limo
    509
    107
    What approx does it cost to repair a wheel bearing ?
    Nexus 6 ?
  9. Taxi/Limo
    509
    107
    There is no vibration I can feel
    Is it advisable to drive the car until I can find out ? is there any way I can determine for sure?
    Nexus 6 ?
  10. bisco
    49,692
    generally, bearing noise will become intolerable before failure. a dealer probably gets close tp 200 bucks.
  11. Taxi/Limo
    509
    107
    Would a tree tire rotation and rebalance be a good place to start? Thanks
    Nexus 6 ?
  12. bisco
    49,692
    a tire rotation might give you a clue if the sound seems to move. i had a flat spot on a tyre, and when i swapped front to back, it got much noisier in the front.
    Raytheeagle likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    If you suspect it is a tire issue, rotate it and if the noise or vibration moves with the tire, now you know what to go after. If it stays in the left rear, now it's something there;).
    Hope that helps(y).
    xliderider likes this.
  14. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Both my gen 2+3 needed f wheel bearings around 40,000, obnoxious noise.
    But a noise from one side of the rear just might be a tire with a torn belt, it should show visually if jacked up and spun.
  15. Jimi1976
    242
    124
    Denver, CO
    I'd guess way more than $200 for a dealer to replace a hub. They'll probably charge 200 alone for the new hub.
    I'm guessing $500 out the door.
    I've done a few hubs in my garage on our cars....one on my Prius....easy to moderate job depending on how easy it wants to come off.
    I drove my Prius with a wearing hub for over a year before it become so annoying, and began to effect mpg
  16. Taxi/Limo
    509
    107
    What's the cost of a bearing replacement ?
    Nexus 6 ?
  17. bisco
    49,692
    i'd guess upwards of $200. at a dealer.
  18. Taxi/Limo
    509
    107
    Is it advisable to drive the car if it is a bearing ?
    Nexus 6 ?
  19. bisco
    49,692
    i think so. they usually get unbearably noisy before they fail.
    tankyuong likes this.
  20. bisco
    49,692
    is it groundhog day?:confused:
